Where does the black fuel sending wire go
Mike69barracuda
Harrisburg, PA
So was the car running before this? Is it a rally dash? On my cuda I believe main feed comes in the round plug. Heres a pic of mine, 8 male pins.
Where does the black fuel sending wire go. What stud? I wrote in sharpie on theback of the dash . When it was in the dash. I'm checking to see if I'm correct. Also I'm putting on an IVR3 limiter. I'll pull away the contacts inside my fuel gauge. BTW 69 Barracuda. Whenputtingin an IVR3 limiter. What happens to the condenser/capacitor on the back of the Instrument panel??? Also on the power circuit board I have a red wire and a red/bla
ck stripe wire that share the same stud. Which stud do these tow wires attach to. THX.
The two poles (terminals), with the nuts on them, are for the "amp (alternator) gauge" on your dash. Red wire goes on terminal marked "red", and black wire goes on the other. Lots of guys solder them together, and by-pass the amp gauge, and install a volt meter.
barracudadave67
Unless you have chopped up the harness, the sender wire connects when you plug in the harness connector
Not intimately familiar with the "rear" of those cluster,s but I believe it's the pin right above the "key" in the connector
The condenser can stay or go, it is for radio noise suppression/ filtering
In other words the three fuel gauge terminals are:
The one with the black cover is the OUTPUT of the IVR, and comes out to feed the other two gauges.
The one with the cap is 12V into the IVR
The third is for the sender which leads directly to a connector pin
Open that fuel gauge and bend some thingy if you want . Just know you don't absolutely have to. When you pull that 3 post instrument from the housing look at its backside. You will find it is grounded to the housing. If you pull any other 2 post instrument you will find they are not chassis grounded. The ground link on the 3 post instrument is the ground for the internal limiter ( and one possible cause of limiter failure ). To interrupt that ground ( a layer or 2 of electrical tape over the little piece of metal they put on the back of this instrument ) disables the limiter completely. It cannot do anything good or bad if it doesn't have a ground.
The only good reason to open the instrument is to see what the thermal gauge part of it looks like. Don't be surprised to find it toasty. If there's a lot of black crud build up on that resistor wire,, If the bi metal beam has a bow at room temperature, its going to need renew service. It can't be cleaned.
The vendors of aftermarket regulators show pics of instruments that look fine. They do know what you "statictically" will find. I've seen fewer that 20 that looked as good and that is of the hundreds I opened during a 8 year period.
And about your "black wire" question... There's a contact pin missing from your board. that is one side of the brake warning lamp wiring and one of those is in fact a black wire so I can't know for sure if you're inquiring about that one of the noise cap' wire. As others have said, you can delete that noise cap' when using a solid state regulator that generates no noise. anyway... that is the 12 volt post ( blue with white tracer is routed to there ). The 5 volts out of your regulator can go where the black plastic cap is but if the wire they provide is long enough, route it to the next one down in that path/trace so you can leave that plastic cap in place. It was put there for a reason. Hope this helps.
