Where to get OEM syncro rings?
tranniedoc
Active Member
Hi,
I have an A833 4 spd (70 Roadrunner) that grinds a little going into 3rd. I recently put in a new syncro hub assy with aftermarket rings. All works good except for the light grinding. I think factory syncro rings would solve the problem but I can't find any. Does anyone know where to get these?
Thanks,
Doug
Doug I'm not a manual trans. guy so I don't really know where to look but you might want to post this in the manual trans. section. It's down farther on the page. You might get more responses there as I'm sure there are a lot of guys here that know manuals. Good luck.
Thanks, I called Brewers and he doesn't have OE syncros but he did give me some advice on prepping the crown gear. I'm gonna try that and put in another set of new syncros.
Thanks again.
