lgjhn
"The faster you go, the faster you go..."
I haven't been on FABO for quite a while now, and I don't believe I've ever started a thread on here before. Being a pretty old fart, I've found it fascinating how engine tech has kinda left me "in the dust" so to speak over the past few years. What was once considered "gospel" in some areas now has newer tech to make it "not so much" anymore. With all that said, here's my situation/question:
The 318 in my '73 Dart Sport was more than tired when I pulled it out. I still ran ok with all the miles on her, but way down on power and started to use some oil. It's time for a serious upgrade on the engine/tranny/rear. I've already completely rebuilt a salvage yard A-body 8.25" with a new set of 3:55s and now have it installed in the car. I've built up a SB 904 tranny and it's ready to go once the engine is completed. I'm wanting to build a good street/strip stroker motor with the emphasis on the "street" side. There are a couple of good, clean blocks available at my disposal. I have an early ('71) LA std. bore 360 as well as a late model std. bore 360 Magnum. As stated, both are in pretty decent shape albeit a lot of miles....they're well-seasoned blocks. Whichever one is used will get a set of the EQ heads on the top side.
I'm wondering what other members feel about which version of block to select: the LA or the Mag? Is there any distinct advantage to the Mag block over the LA when all things else considered would be the same in the build? Maybe oiling? Thanks.
