Which alt to use ?
Electrical and Ignition
  1. A Body 440 WHY NOT
    A Body 440 WHY NOT Well-Known Member
    301
    112
    Sep 28, 2019
    Jersey
    Local Time:
    7:05 AM
    Hi all,
    Working on my 440 69 dart project. Getting to the altenator . I am not interested in a external regulator or originality. I am thinking about a GM 2 wire alt. I would imaging you could just not use the one wire that goes to the warning light ? Other wire goes to batt. And output naturally goes to batt. Anybody mount one of these , or is there a better way.
    thanks :thumbsup:
  2. Mattax
    Mattax Just the facts, ma'am FABO Gold Member
    11,263
    7126
    Feb 7, 2013
    Phila. Pa
    Local Time:
    10:05 AM
    The simplest wiring to understand and the most straight forward install will be a Chrysler with a one insulated field terminal, and a positive controlling regulator.
    A later Chrysler with two insulated brushes will fit and work the same if one is grounded.
    If the car will need more electric power (ie EFI, electric fans, etc) then look at the 'Denso' alternator setups AndyF has made brackets for. Wire to use the matching regulator. Increase the alternator and battery output wires sizes to match the demand ((ie EFI, electric fans) and the possibility of higher battery recharge currents.
  3. Oldmanmopar
    Oldmanmopar Going left turning right FABO Gold Member
    8,998
    5457
    Jan 8, 2009
    Danielsville Pa. 18038
    Local Time:
    10:05 AM
    Get a one wire GM . The best you'll ever buy. I run a 100 amp one wire . Shut it off before entering the water box and turn it on after the traps.
  4. dano
    dano Evil Handy Man
    3,502
    1389
    Aug 22, 2005
    Gresham, Oregon
    Local Time:
    7:05 AM
    I went the Denso rout. Smaller, lighter cleaner looking and no external regulator. It documented on how to wire and they are easy to come by. I really like the Ford 3G alternators too.
    • Like Like x 1
    • DrEamer
      DrEamer I suffer from cars on the brain!
      454
      590
      Mar 9, 2019
      Oregon
      Local Time:
      7:05 AM
      Powermaster makes one wire stock alternators, or the newer Denso depending on how many amps you want to run.
      • Like Like x 1
      • Kendog 170
        Kendog 170 Let the boy go !
        1,649
        1069
        Mar 10, 2016
        Tewksbury Ma.
        Local Time:
        10:05 AM
        I went the Denso route too. Stock brackets , just make new spacers. (Pic is not mine) Internal regulator. 1 wire output, 1 wire sensor wire, 1 wire warning light.
        • Like Like x 2
        • Kendog 170
          1,649
          1069
          Mar 10, 2016
          Tewksbury Ma.
          Local Time:
          10:05 AM
          Better pic (440) Mancini has kits also.
          • Agree Agree x 1
          • Mike69cuda
            Mike69cuda 64 is the new 17 FABO Gold Member
            1,988
            1548
            Jan 2, 2018
            Overland Park Kansas
            Local Time:
            9:05 AM
            Hey OMM, There was a discussion on this awhile back. The GM alternator you are using has just one and only one wire going to it?
          • Kendog 170
            1,649
            1069
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            10:05 AM
            You can use one wire with the Denso but you have options. 1- a warning lamp. 2- The sensor wire can ease back on charging if no charge is needed.
          • Kendog 170
            1,649
            1069
            Mar 10, 2016
            Tewksbury Ma.
            Local Time:
            10:05 AM
            • Thanks! Thanks! x 1
            • Kendog 170
              1,649
              1069
              Mar 10, 2016
              Tewksbury Ma.
              Local Time:
              10:05 AM
              • Like Like x 1
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                46,499
                14339
                Oct 14, 2010
                Idaho
                Local Time:
                7:05 AM
                I dislike "one wire" for several reasons. They are more difficult to deal with with trunk mount batteries. Some of them don't excite until they are "revved" above a certain shaft RPM. And they require MUCH larger charge wires for proper operation, because the "one" wire IS the sense wire
                Older GM 2 wire: Be careful. You cannot simply apply key-switched power to the excitation on the older one. This is the lamp circuit and you need at least a diode. It may work for awhile but "one day" conditions will happen that the diode trio will blow up because there is no isolation. Other than that, they worked fine
                I prefer external regulator for ease of troubleshooting, but that is my preference. You must make sure the VR is grounded to "same as" battery and little drop in harness for proper charge voltage. Same for "3 wire" integral regulator.
                • Like Like x 1
                • Agree Agree x 1
                • A Body 440 WHY NOT
                  301
                  112
                  Sep 28, 2019
                  Jersey
                  Local Time:
                  7:05 AM
                  301
                  112
                  Sep 28, 2019
                  Jersey
                  Local Time:
                  7:05 AM
                  Thanks everyone !
                • DrCharles
                  DrCharles Well-Known Member
                  1,125
                  908
                  Jun 7, 2012
                  West Plains, Mo.
                  Local Time:
                  9:05 AM
                  Don't tell anyone, but I have a CS-130 (2-wire GM alt) on my Dart. It puts out more than enough even at idle to run everything electrical with room to spare (headlights, fuel pump, electronic ignition, heater fan, and 40 amps for the Contour fans on full).
                  Got it for $20 at a swapmeet, figured it was a core, Autozone tested it for free and everything met spec :)
                • famous bob
                  famous bob mopar misfit
                  18,346
                  7729
                  Aug 14, 2011
                  okla
                  Local Time:
                  9:05 AM
                  I run the same one , mounted down where the fuel pump would normally be ---------under the motor plate , and home made alum. brackets and adjustment rod.
                  Lines up perfectly w/ the stock single belt big block pulleys , back of water pump milled the thickness of the motor plate .
                  • Like Like x 1
                  • plymouth4onthefloor
                    plymouth4onthefloor FABO Gold Member FABO Gold Member
                    145
                    95
                    Dec 1, 2017
                    Switzerland
                    Local Time:
                    4:05 PM
                    I run the Powermaster 80A Mopar style in my Satellite, troublefree. I have to use a high Amp alternator because my fan draws 50A!
                    Please increase wire diameter if you run high amps.
                    By the way, i love the Mopar look......
                  • Oldmanmopar
                    8,998
                    5457
                    Jan 8, 2009
                    Local Time:
                    10:05 AM
                    Yes only one wire that goes directly to the battery. On my car it goes to a remote battery connection. "Positive bulk head bought at Deka Battery". My battery is in the trunk an the bulk head is the connection for positive battery under the hood. The first picture the black wire is the only wire needed for alternator. The second picture you can see a solenoid wired in to shut the alternator off. I had to do this because I kept throwing the belt over 8000 RPM's
                    • Like Like x 1
                    • Dfr360cuda
                      Dfr360cuda MAGA Again
                      1,636
                      1049
                      Aug 30, 2012
                      Finleyville, PA
                      Local Time:
                      10:05 AM
                      You have a big block... Me too
                      You have a motor plate... Me too
                      You have an aftermarket alternator setup... Not yet
                    • famous bob
                      18,346
                      7729
                      Aug 14, 2011
                      okla
                      Local Time:
                      9:05 AM
                      I have a pic , but darned if I can bring it up !
