Which "drag race" master cylinder?
Anyone using the 131323M - supposed to be for a 70 340 Duster 15/16 bore Disc / Drum setup?? I was planning to install one in my 72 when I get the 11" discs up front and the 11" dana drums out back...
Not using that size MC, but the theory is the bigger the brakes and pistons, the bigger bore and volume MC is needed.
heres what i run on my duster
has the adapter plate
85 or dodge truck
and run dot 4 brakefluid
Seeing as i just installed Wilwood brakes i'm using their "light weight" master part #260-4894:D:D
Just to followup. The only aluminum one I could find was actually to a fwd dodge spirit or daytona. The reservoir has a slight downhill to it. Other than that it works great. 22 bucks I think. Many of the go to apps people used to buy I have found are now mad with cast iron bases. If you just want the small one, and dont care about weight, then those would work fine. But aluminum was what I was hunting for.
I have the 73 up A body disc brake setup on my 64 Sport Fury. Upgraded to the larger 11 3/4 rotor. Didn't stop very well. Went to the 76 up Aspen calipers, which are larger than the A body. Can't remember the exact size. No brakes with a 15/16 bore. Went to a 1 1/32 bore MC. Stopped much better. So calipers bore size is important. I also went with smaller bore rear wheel cylinders. That helped too. Sometimes you have to do a little trial and error.
" Getting wrapped up in it " wasnt directed at you, sorry you took it that way.
What I was trying to say, was as a whole, many people get all wrapped up in the bore thing.
I have used different disc MC's, and in my experience, they all feel the same.
a 1/16" inch increase in master cylinder bore size requires a 12% increase in leg for the same pressure
a small 15/16" master and a 'cuda 2 3/4" caliper piston will stop effortlessly,almost like power brakes.
..if you go from 15/16 master to 1 1/16 you will require 24% more leg
Exactly backwards
smaller master increases pressure but increases pedal travel .
15/16 bore master and 2 3/4 piston (cuda caliper ) on an a body will stop effortlessly
1 1/8 bore master and 2 5/8 piston (a body caliper) will make stopping very difficult
a 1" master with 100lb of leg will produce about 3600 psi with the a body 2 5/8 caliper
a 1' master with 100lb of leg will produce about 4400 psi with the e body 2 3/4 caliper
a 15/16 master will increase the pressure even more but there will be a bit more pedal
travel.
use the small master and larger disc caliper and you will have great brakes.
Exactly backwards
travel.
^^^^^^ Xs2.....
you guys make me sweat here. ive got wilwood on all 4s and the larger wilwood mc 1.19 no power booster. all is brand new not even filled with fluid yet. i am about to in the coming days or weeks bleed them and see how it works. am i gonna need to stand up on the pedal to get brakes to stop? should i go down to a smaller mc before even trying the big mc? very fast drag rwving but also a street cwr that will see lots of street miles on weekends.
Mine is listed in metric. Just a sliver over 1 inch. Wilwood fronts. Wouldnt want it any stiffer.
MC before this setup was the 1.125 with factory style disc. Again pretty stiff.
Both stop the car fine at the track. Would I want to take a 500mile road trip? No.
That being said....try what u have. I have rear drums. Dont use these opinions to take your setup apart...it may be just fine for your liking.
First, I don't get all the "stops good" or "didn't stop good" due to a different MC. Tires stop the car and brakes stop the tires unless they overheat (drawback of drums). The MC just makes pressure. So, these guys must be talking about "pedal effort required to make a certain pressure". A smaller bore requires less pedal effort, at the expense of more pedal travel (depends on sponginess of hoses, air bubbles, slightly fluid compressibility).
If you use a 4-2 bolt adapter plate ($30 ebay), you can use many MC's. I use one for a 95-99 Breeze (w/ ABS) on all my old Mopars. It has 7/8" bore. Many here use an 80's truck MC (post 28 ), or buy the same PN for 2x price at speed shops. Don't go too new or you must deal w/ "bubble flare" ports. Also plumb an adjustable proportioning valve in series w/ the rear tube.
