which hyd clutch master cylinder?
srixon4406
TURBO TOAD
Clarklake Mich
I'm in the process of building a /6 turbo 62 valiant and I'm putting in a A833 OD trans and I'm changing the Z bar linkage out to a hyd slave from a early 70's dodge truck setup and I was wondering what clutch master cylinder people were using in the early A bodies
Here is the link for the slave bracket
http://www.bigblockdart.com/techpages/clutch.shtml
Turbo Toad
I would try to use a clutch master cyl from an early 70's truck if there is enough room to mount it, that way you"ll Know the bore sizes and stroke will work with each other. Also try and find a truck to look at or a picture of where the master cyl attaches to the clutch pedal so you can measure how far down on the pedal to mount the push rod for the master cyl.
