which master cylinder?
Brakes for your Classic Mopar
  1. roadrr
    roadrr Member
    12
    1
    Apr 24, 2017
    iowa
    Local Time:
    1:22 AM
    so ive been digging through post to no avail! i see where people ask which master cylinder for a 1970 duster 340 with front manual disk and manual rear drum and get recommedations but nothing definate on what was used, so again what master cylinder is a good replacement that people have used and works. with part numbers if possilble and where purchased please, anybody
  2. Fast340cuda
    Fast340cuda Well-Known Member
    211
    121
    Jul 25, 2013
    San Jose, ca
    Local Time:
    11:22 PM
    I used one from a 1973 Dodge Dart (disc version) on my 68 barracuda with factory front disc (same as your application).
    I would check Rockauto for part number reference from the various manufacturers then buy one off of eBay or Amazon.
  3. mvh
    mvh FABO Gold Member FABO Gold Member
    1,615
    348
    Dec 17, 2007
    Menlo Park, CA
    Local Time:
    11:22 PM
    The problem is that the brake part manufacturer application listings for A-body disc brakes are thoroughly screwed up. In theory, there should be two 1967-72 disc brake master cylinders: one for Manual with a 1-1/32" bore, and one for Power with a 15/16" bore (otherwise interchangeable). But you will find a lot more variations in part numbers than just those two, and some of the listed items will actually be drum brake masters. Annoyingly, most store sites don't give the bore dimension, but you can Google the part number and find a manufacturer listing that will show it (Cardone or Bendix, for example). That said, it is frequently recommended that you use the Power master cylinder for Manual disc brakes — the smaller bore reduces the pedal effort while slightly increasing the pedal travel — most people today seem to find that a reasonable trade off. I have one car with each, and I can tell you that the 15/16 bore MC feels plenty hard — the 1-1/32 bore feels like you need both feet (great for threshold braking at the track, but startling if you step into it from a modern vehicle). There are also other versions of the same basic master cylinder with other bore sizes — 1" is common on B-bodies, and 1-1/8 is also encountered. So I don't trust the application listings — I research the specs for the part shown to ensure it has the bore I want.
    • Like Like x 1
    • Dartsun
      Dartsun Mopar Dude
      2,095
      1856
      Feb 12, 2012
      Springfield Oregon
      Local Time:
      11:22 PM
      For my kelsey hayes manual front disc 10” rear drums I went with this master cylinder. So far so good been a few years now.
      • Agree Agree x 1
      • Joey4speed
        Joey4speed FABO Gold Member FABO Gold Member
        1,297
        981
        Jul 17, 2018
        Coastal NC
        Local Time:
        2:22 AM
        Google
        MOPAR MASTER CYLINDER GUIDE BY THE RAM MAN.
        These 5 pages explains it all, great if you want the correct
        look that works.
        Also see thread from September:
        WHAT MASTER CYLINDER ?
      • mrhp
        mrhp Well-Known Member
        100
        38
        Jun 24, 2005
        SoCal 91942
        Local Time:
        11:22 PM
        This is a good thread too: upgrade master brake cylinder
        To my knowledge, there are no exact rebuilt replacements available and there is no kit available (The one from Dorman is for drum/drum).
        The later '73 on up style iron 15/16" bore ones will work fine however they are larger in size. The 15/16" DoctorDiff, while looking more modern, is a welcome 'no leak' style.
        I recently did the DoctorDiff. Until my stock one started to go bad, it was a very hard pedal. The DoctorDiff is definitely an improvement.
        • Agree Agree x 1
        • 70chall440
          70chall440 Mopar or No Car...
          467
          520
          Jun 9, 2018
          Yelm WA
          Local Time:
          11:22 PM
          My information shows PN 2808600 casting no 2225411 for 67-70 A body, 1" bore diameter.
          • Like Like x 1
          • inertia
            inertia Well-Known Member
            3,454
            726
            Feb 4, 2011
            Victoria B.C. Canada
            Local Time:
            11:22 PM
            This is a new 15/16 m/c.
            Straight bolt on, no fuss, no mess, no adapters.
            This is prefered by most spirited drivers for it's feel and modulation, while maintaining the "original" look . .
            More Information for RAYBESTOS MC36406
            • Agree Agree x 1
            • roccodart440
              roccodart440 Well-Known Member
              5,749
              4734
              Apr 19, 2010
              Local Time:
              2:22 AM
              I run a 7/8 on my manual brake setup
              • Agree Agree x 1
              • famous bob
                famous bob mopar misfit
                19,385
                8473
                Aug 14, 2011
                okla
                Local Time:
                1:22 AM
                Wish I`d gone 7/8 , installed 15/16 on my 4 wheel manual disc setup ..
                What brand 7/8 ----??
              • roccodart440
                5,749
                4734
                Apr 19, 2010
                Local Time:
                2:22 AM
                Wilwood
                • Thanks! Thanks! x 1
                • BillGrissom
                  BillGrissom Well-Known Member
                  7,496
                  451
                  May 10, 2009
                  Sacramento
                  Local Time:
                  11:22 PM
                  An inexpensive 7/8" bore MC which works is for a 1995-99 "cloud car" (Breeze, Stratus, Cirrus) w/ ABS (2 ports). You will need a 2 to 4 bolt adapter plate ($30 ebay). I have one on my 1964 Valiant (manual), 1965 Dart (w/ Intrepid booster on Dart firewall brackets, see profile photo), and 1965 Newport (2-4 adapter to factory booster). Search for my post w/ photo showing that the pedal winds up in the same place w/ the Breeze MC on adapter plate as the factory manual MC. I have a new MC w/ reservoir on the shelf now as a spare for all 3 cars, which might have cost $25 on ebay.
                  I expect something from the GM or Ford racks might also work. I just grabbed something newish from the Mopar rows while at PicNPull years ago. If you go with a 2000+ MC, you run into bubble-flare fittings, which you can form with an old dbl-flare tool (youtube), but why bother.
                • Jet
                  Jet Well-Known Member
                  67
                  77
                  Dec 11, 2015
                  Ocala
                  Local Time:
                  2:22 AM
                  Dorman M39736
                • 1969moparDART
                  1969moparDART Well-Known Member
                  214
                  31
                  May 15, 2018
                  texas
                  Local Time:
                  1:22 AM
                  do you have a link to the one you got from dr diff?
                • mrhp
                  100
                  38
                  Jun 24, 2005
                  SoCal 91942
                  Local Time:
                  11:22 PM
