IIRC stock magnum 5.9 cams were only about .400 lift, but the 318 was more like .450. the 5.9 might have had a little more duration...I think the 318 was only like 250 adv duration on the intake side.....gave away my '97 ram FSM to my neighbor down the street who inherited a '99 ram from his dad, so I can't look it up anymore.
Here is what
@YY1 posted for numbers.
5.2 Magnum Hydraulic Roller 432/432 251/264 113CL
5.9 Magnum Hydraulic Roller 410/417 249/269 109CL
Here are the numbers I got from having a 2000 Ram 5.9 cam run through the Cam Doctor at Bullet Cams:
Duration @ 0.050: I/E 189*/194*
Lobe separation angle: 111*
Lift @ cam: I/E 0.273"/0.278"
Valve lift w/ 1.6 rockers: I/E 0.437”/0.445”
Not sure on the advertised duration numbers, but my 5.9 cam had more lift than both the 5.2 and the published 5.9 numbers.
One interesting point that YY1 made someplace (as I recall) is that the published valve lift numbers for the 5.9 match the cam lift numbers from my cam if you use a 1.5 rocker ratio. So it is possible that info like that was just done wrong, but the rest of it is correct. No sure, just pointing it out.
If we assume the advertised duration is correct on the numbers from YY1, the 5.9 cam is a couple of degrees smaller on the intake but larger on the exhaust and my lift number say both are taller on the 5.9 cam.
Based on that, I don't believe the 5.2 cam is better. Frankly, I think both are so small it wouldn't make much difference either way.
