1. 4geardemon
    4geardemon Well-Known Member
    262
    102
    May 17, 2015
    Canton, SD
    Local Time:
    2:55 AM
    I have a 318 in my Demon that has a tired bottom end. Lacks oil pressure when it is warmed up at an idle. Holds 25 lbs at the least running down the highway. I am in the process of building a 440 for it but am not pulling the 318 until it blows or the 440 is ready. Right now I run 10-40 Valvoline in it. Has anyone ran diesel oil in a gas motor? Like Rotella 15-40 or other brands? Just trying to extend the life of it so I can keep driving the car till motor is built.
  2. mguner
    mguner How many is too many?
    5,129
    364
    Nov 26, 2006
    Amarillo,TX
    Local Time:
    2:55 AM
    I run 15w-40 diesel blend from Motorcraft.
  3. inertia
    inertia Well-Known Member
    3,467
    739
    Feb 4, 2011
    Victoria B.C. Canada
    Local Time:
    12:55 AM
    Run 20/50.
  4. 71DodgeDemon340
    71DodgeDemon340 FABO Gold Member FABO Gold Member
    2,446
    648
    Apr 2, 2011
    Tennessee
    Local Time:
    3:55 AM
    Depends on your climate. If in weather say 60 degrees and above 15w-40 or 20w-50 should be fine
  5. Motopsycho
    Motopsycho duster domination
    10,571
    328
    Aug 5, 2008
    indiana
    Local Time:
    3:55 AM
    lucas oil
  6. mguner
    5,129
    364
    Nov 26, 2006
    Amarillo,TX
    Local Time:
    2:55 AM
    Just make sure it has the proper additives to keep that flat tappet cam alive!
  7. 318willrun
    318willrun Utube channel 318willrun
    16,986
    19041
    Sep 13, 2013
    I'm here
    Local Time:
    2:55 AM
    you'll never install that 440...... 'cause that 318 ain't blowin' up... just say'n
  8. Breadburner
    Breadburner Well-Known Member
    368
    23
    Jul 20, 2015
    Oklahoma
    Local Time:
    2:55 AM
    Straight 30.....
  9. 4geardemon
    262
    102
    May 17, 2015
    Canton, SD
    Local Time:
    2:55 AM
    What additives need to be there for a hydraulic purple stick? When the 440 is built the 318 is coming out no matter what. Lol. I don't want to run expensive oil since it isn't anything totally powerful or special like a race motor and what not.
  10. MOPARMITCH
    MOPARMITCH Mekong Gold Member FABO Gold Member
    22,591
    15567
    May 15, 2013
    Maryland
    Local Time:
    3:55 AM
    Zinc !!
    • Like Like x 1
    • MrJLR
      MrJLR Built, not bought FABO Gold Member
      5,147
      5435
      May 14, 2015
      Chino, California
      Local Time:
      12:55 AM
      x2
    • MOPARMITCH
      22,591
      15567
      May 15, 2013
      Maryland
      Local Time:
      3:55 AM
      Or 40
    • 4geardemon
      262
      102
      May 17, 2015
      Canton, SD
      Local Time:
      2:55 AM
      Thanks all! I got 15-40. Big old brain fart on my part for the zinc. Put too much thought into it. Haha.
    • WildCat
      WildCat Well-Known Member
      3,546
      88
      Dec 29, 2007
      Southern Indiana
      Local Time:
      3:55 AM
      When they took the zinc out of passenger car oils many starting using the diesel oil since it still had it, but I believe they have taken it out of them also
      In a tired old 318 in warmer weather straight weight oil might be best. The 15w40 diesel oils would be good and in warm weather 20/50 would be ok also
      Really if it carries oil pressure at idle, 2-5 lbs would be ok as long as the lifters don't start rattling you have enough oil getting everywhere
      In the new engine you will want to make sure you use a zinc additive or a racing oil with it, unless you have a roller cam and rockers
    • Breadburner
      368
      23
      Jul 20, 2015
      Oklahoma
      Local Time:
      2:55 AM
      Look at Brad Penn for your new 440.....
      • Like Like x 1
      • GEO
        GEO Sarcasm Inc.
        1,928
        232
        Feb 12, 2012
        Irvington ,Indiana
        Local Time:
        2:55 AM
        15w50 Mobil-1 has the zinc for flat tappet cams
        • Like Like x 1
        • 71DodgeDemon340
          2,446
          648
          Apr 2, 2011
          Tennessee
          Local Time:
          3:55 AM
          X2^
        • Al Bundy
          Al Bundy four touchdowns!
          219
          5
          Aug 2, 2015
          California
          Local Time:
          2:55 AM
          I always used Valvoline Vr-1 racing oil,it has the zdddp our older engines need. It's a Dino oil to,so no need to worry about it cause old seals to leak
        • 66fs
          66fs FABO Gold Member FABO Gold Member
          5,605
          2163
          Sep 9, 2009
          Greenwood, South Carolina
          Local Time:
          3:55 AM
          Give Straight 30 or 40 or 20w50 Valvoline racing a try. Should get you another 5 or 10 psi cruising.
        • jfleming64dart
          jfleming64dart Well-Known Member
          47
          2
          Dec 1, 2015
          Rome & Hempstead NY
          Local Time:
          3:55 AM
          I'll say this though, oil weight may not do jack if things are too worn out in the bottom end. My girlfriend's father has a '68 Ford Galaxie he lefts lets me drive, which used to bottom out near 0 oil pressure at red lights. I know its not a mopar engine but my point is: new oil pump, no leaks, and we tried 20w50: got us up to about 5 PSI at the red lights. We live with it, but I'm just saying viscosity won't always make too much difference.
        • 66fs
          5,605
          2163
          Sep 9, 2009
          Local Time:
          3:55 AM
          Just a band aid till he gets his new motor done.
        • mech1nxh
          mech1nxh CUSTOM TITLE FABO Gold Member
          5,849
          3711
          Jan 20, 2009
          Local Time:
          12:55 AM
          Lol (at Myself) I had to do this 'band aid' thing once.
          I used 3 QT's of Delo 400 & 3 QT's of Cevron 80-90 wt Gear oil.
          LOL, sometimes 2k more miles takes the pressure of a limited budget :D
        • BigBlockMopar
          BigBlockMopar BigBlockMember
          1,760
          761
          May 1, 2011
          Netherlands
          Local Time:
          9:55 AM
          20w50 or even Gear oil works fine in an old worn engine struggling for oilpressure.
          If the engine is bone stock (cam/spring), then zinc-additive is irrelevant at this point.
          As long as there some hydraulic film or fluid pressure between the bearings, it will live.
        • toolmanmike
          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
          58,697
          46107
          Jan 18, 2006
          Iowa
          Local Time:
          2:55 AM
          X2 at this point, any thick oil will do the trick. You don't need to be fussy.
        • j par
          j par Well-hung Member
          27,750
          15174
          Jul 2, 2014
          Portland Oregon
          Local Time:
          12:55 AM
          Torco 10 - 30
