Which vac pot gets which hose? '68 'cuda
gregcon
'68 A body with factory AC
I've had the hoses off for so long I don't remember which hose goes where...does anyone have a diagram?
The factory service manual shows Hose #1-7 (#6 is engine vacuum) going to the three different vacuum pots...but it's a drawing done such that it doesn't really identify which pot is located where.
I need to know which hose (1,2,3,4,5,7) goes to which pot and if it is on the rod side of the pot or the opposite side.
Vac pot up top, near heater core tubes
Vac pot down low, closest to floor of car
Vac pot on side, near passenger kick panel
Thanks!
Here are some pictures I took of mine before taking it apart. I have it sitting on the bench at work still so I should be able to get them all to you today sometime. Dam photobucket being a pain. If you click on the pic it will take you to my photobucket page and you can scroll through them
Thank you! I've since figured out which hose goes where.....I think.
I had the idea that my 68 FSM was so bad in this area that they must have improved it...so I looked in a 71 FSM and sure enough there is 'improved' information. By using the two books together I was able to come up with a guide.
It doesn't help matters that they use different names for the same part!
I'll post later today for future reference.
