Here is a pic of the B&M external balanced flex I just put on my 360 for a 727 I bolted up about two weeks ago. Hope this helps somewhat. The larger flat part of the plate is closer to the block. Mine said in small stamped letters (hard to see almost) "engine side" on the side that goes toward the block. I used ARP bolts with locktite also.
