which way does this bushing go in?
freshayr
help me out....which way does this bushing go in? This is the front strut rod bushing.
http://www.moparts.com/Tech/Archive/susp/10.html
It should mount with the fatter end facing the front of the car. The smaller end goes through the frame from the front facing the rear. You then slide in the strut rod with a washer on it into the bushing, then on the end place a washer & nut. Figure 7-4 should help in the link I included.
Hope this helps....:thumrigh:
