mopar56
Ok so because I know we need the facts this ISNT a A body, I'm working on my hot rod but the frame and brakes are a 81 D150 2wd, so it is 10 inch front disc brakes and rear drums, 10 inch again if I remember correctly with the factory proportional valve, and manual brakes, the master cyl is the only difference here as I used a pedal box from a 82 b150 , ( van) here is the issue, I bench bled the master cly the usual way dumping fluid from the outlets back into the resvoir ( plastic/ aluminum) then when I go to bleed the brakes, ( by myself using a vacuum style pump) the fluid flows fine to the calipers but nothing goes to the rear, I disconnected the line from the proportional valve to the rears and no fluid flows when I pump the pedal, I pulled on the reset button on the valve and tapped lightly with a hammer but when I push on pedal I get no fluid my next step I was going to try was completely bleeding the fronts and hooking the rear line back up and stepping on the brake pedal I have read this can reset the spool in the valve, I also tried some compressed air through the line coming from the master to the valve but I don't see fluid, this truck frame has not been on the road for years BUT I replaced all the wheel cyls , calipers, hoses, and lines, only the proportional valve is original and the b-van m/c is not new but seemed to bleed out ok. Ideas????
