Why Tire Rub Now?
Mopar Body and Trim
  1. LyinBrian1
    LyinBrian1 Member
    10
    15
    May 7, 2017
    Ashland
    Local Time:
    6:02 PM
    I recently purchased the below '72 Swinger. The previous owner had added '71 rally wheels with 245/60R14 BF Goodrich Radial TA rear tires and 205/70R14 fronts
    He replaced the suspension with new parts and added a Suregrip rear end.
    I've owned it for a month and other than a hot start issue with the Eddy 4 barrel, this car has been a dream come true.
    Last night however we were cruising and I made various right turns and three times the right rear tire rubbed on the fender.
    They're three turns I've made dozens of times since purchasing and have never had a problem. Why now?
    There's about .50 clearance on each fender and like I said have never had a problem before.
    I'm worried (I'm a worry wart LOL).
    Anything I should have checked or was it just the way it is and I need to be careful?
    • Like Like x 2
    • dano
      dano Evil Handy Man
      4,073
      1913
      Aug 22, 2005
      Gresham, Oregon
      Local Time:
      3:02 PM
      Was anyone in the car with you?
      I'd check the rear suspension, bushings, and axle mounting to be sure its all sound and tight. 245/60/14 is a fat tire by nature of the large sidewall having some flex is another possibility.
      • Like Like x 1
      • Agree Agree x 1
      • mopar505
        mopar505 FABO Gold Member FABO Gold Member
        295
        130
        Jan 19, 2014
        pa
        Local Time:
        6:02 PM
        NICE RIDE..............may want to check the leaf spring to axle u-bolts and insure they are tight. if the PO had the entire rear replaced, after driving sometime you are supposed to re torque those bolts. other than that excess body roll ??
        • Like Like x 1
        • cudascott
          cudascott It’s a sickness!
          1,966
          925
          Jan 11, 2012
          TN
          Local Time:
          6:02 PM
          Did you check tire pressure?
          • Like Like x 1
          • Agree Agree x 1
          • 1969reddart
            1969reddart or is it Copper...
            310
            329
            Sep 29, 2007
            Concord, Ca.
            Local Time:
            3:02 PM
            I have the same width tire on my Dart. My rear tires would rub when I entered a tight turn driving a little faster than the speed limit. When I added a 1 1/8" Hellwig front sway bar, it quit rubbing.
            Extra passengers in the back could be a problem also.
            Nice looking Dart...
            • Like Like x 1
            • 69_340_GTS
              69_340_GTS Well-Known Member
              4,588
              3045
              Jul 11, 2014
              Torrington, CT
              Local Time:
              6:02 PM
              Dang, that is a beautiful car! Great colors.
              • Like Like x 1
              • Agree Agree x 1
              • abodyjoe
                abodyjoe Well-Known Member
                21,971
                8379
                May 22, 2004
                Berlin,N.J. 08009
                Local Time:
                6:02 PM
                did the sidewalls rub or was it the tread up top of the wheel well? there is a kickout up there that can hit the tire.. maybe the springs settled or you have just a little more weight in the car and that was the difference. it does look to sit real low in the rear.
                • Like Like x 1
                • abodyjoe
                  21,971
                  8379
                  May 22, 2004
                  Berlin,N.J. 08009
                  Local Time:
                  6:02 PM
                  always loved that color..
                  • Like Like x 1
                  • Cuda68Scott
                    Cuda68Scott Well-Known Member
                    605
                    252
                    Nov 28, 2009
                    Arizona
                    Local Time:
                    4:02 PM
                    Wow, that is a great looking car! Wonder if your front shocks are still good? I suppose they are new? Also remember hot summer temperatures increase tire pressures and I also think the heat affects all the front end components to some extent.
                    • Like Like x 1
                    • 72bluNblu
                      72bluNblu FABO Gold Member FABO Gold Member
                      11,779
                      6617
                      Nov 28, 2008
                      NorCal
                      Local Time:
                      3:02 PM
                      Gotta check everything as already mentioned, could be a lot of things causing the rub. But if the rear springs were changed recently and the last owner didn't do a ton of driving the springs may be settling in, and the slightly lower ride height is causing the rub. Something to consider if everything checks out ok otherwise.
                      • Like Like x 1
                      • BoogieMan67
                        BoogieMan67 FABO Gold Member FABO Gold Member
                        316
                        151
                        Dec 24, 2016
                        Tennessee
                        Local Time:
                        5:02 PM
                        Looks like the car southern motors in mich.had nice car:thumbsup:
                        • Like Like x 1
                        • jos51700
                          jos51700 Green Bearing thread connoisseur
                          5,961
                          2731
                          May 24, 2009
                          Bel-Ray
                          Local Time:
                          5:02 PM
                          Check every fastener from leaf spring hanger, front and rear, to leaf spring bushing, to axle u bolts, and checking the axle retainer bolts would not hurt either.
                          If not already installed, consider the poly leaf spring bushing set WITH SPACER or shouldered stud, to limit lateral deflection.
                          Good
                          Bad
                          In the Middle (no pun intended)
                          • Like Like x 1
                          • LyinBrian1
                            LyinBrian1 Member
                            10
                            15
                            May 7, 2017
                            Ashland
                            Local Time:
                            6:02 PM
                            Yep. That's the car. Delivered in late April.
                          • LyinBrian1
                            LyinBrian1 Member
                            10
                            15
                            May 7, 2017
                            Ashland
                            Local Time:
                            6:02 PM
                            Thanks everyone! We're gonna check everything out.
                            PS it was sidewall run.
                          • mcpherson57
                            mcpherson57 Well-Known Member
                            220
                            31
                            Nov 21, 2006
                            Mid Michigan
                            Local Time:
                            6:02 PM
                            I had a problem like that. I put a brand new set of super stock springs on a 68 and within 3 years they had zero arch left in them. I replaced them with a new set of heavy duty springs and gained about a inch and three quarters of height. Then I took the SS springs to a spring shop had had the re arched and added a leaf and put them on another car and fixed it's tire rub problem.
