have unequal length axles on a stock length dana 60 in a dart
You mean any reason other than the pinion not being centered?have unequal length axles on a stock length dana 60 in a dart
Because that is the way they were built.have unequal length axles on a stock length dana 60 in a dart
Certainly is a pain for any of our right hand dive cars any V8 as our steering box is mounted to the chassis rail not the k frame and doing points and condenser on a leaning tower of power is also difficultThe engine is NOT centered in the engine bay; it is offcentred towards the left The actual amount varies as to which book you read.....I believe the reason for this was to provide more clearance for the steering box. [ You can imagine the nightmare of installing headers on BBs in rt hand drive cars...].
The diff centre needs to be offset the same amount to keep the drive line angles parallel. Think of pinion angle, but in the horizontal, not vertical plane. So axle length could be different depending on the diff centre design.
..........doing points and condenser on a leaning tower of power is also difficult..........
He is referring to the Australian cars where the steering box is mounted on the frame very near the distributor on the slant 6...How on EARTH do you figure that? I can have the distributor out, serviced and back in and running in around 30 minutes. What's not to love?
Thanks. Gotta picture?He is referring to the Australian cars where the steering box is mounted on the frame very near the distributor on the slant 6...
