Will a Stock 489 handle 700hp?
Mopar Racers Forum
Have you had a stock 8.75, 489 hold up to 700hp while racing?
  1. Yes
    11 vote(s)
    28.2%
  2. No
    28 vote(s)
    71.8%
  1. 70DusterBob
    70DusterBob Well-Known Member
    713
    167
    Feb 20, 2016
    Texas
    Local Time:
    4:14 PM
    I have about a 650hp 408 H.P. that has a H.P. 727 behind it 2,500 stall. It is time to put a diff in. Some people are telling me a stock 489 8.75, with stock gears, race axles, stock pinion yoke, stock bearings, etc, will handle 700hp with an Automatic Trans.
    Some people are telling me I need this pumpkin for it:
    Mopar 8 3/4" (8.75) 489 Case Third Member
    I want the green bearings, a 3:23 ratio, 6 Helical Gear Sure Track II, w/a 1350 Yoke.
    Problem is I can get a stock pumpkin for $850, while the race pumpkin with the above features is $1,425. Don't get me wrong, I am not out to pinch penny. What I don't want to do is spend the money on a race pumpkin when a stock one will do. If the stock will not do, I will definitely buy the race pumpkin. No Problemo! I have heard a lot of different answers.
    Members who have experimented in this area will prove most helpful. I need to know what your experience was.
  2. 1Badcolt
    1Badcolt Well-Known Member
    2,179
    894
    Mar 15, 2013
    Georgia
    Local Time:
    5:14 PM
    700 HP [ WOW ] Mongo Like !!!
    • Agree Agree x 2
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      70,610
      45449
      Jun 7, 2010
      Georgia
      Local Time:
      5:14 PM
      Yeah as long as you don't try to hook up.
      • Agree Agree x 5
      • Like Like x 2
      • toolmanmike
        toolmanmike FABO MODERATOR Staff Member FABO Gold Member
        58,113
        45172
        Jan 18, 2006
        Iowa
        Local Time:
        4:14 PM
        Strange S60
        • Agree Agree x 9
        • Like Like x 2
        • j par
          j par Well-hung Member
          27,548
          14963
          Jul 2, 2014
          Portland Oregon
          Local Time:
          2:14 PM
          Stock 489 case.. spool, 475hp, 4 speed, very sticky tires... Where there's a will there's a way...
          That same 4.10 - 8 3/4 ring gear next to the replacement D60 - 4.10 ring gear...
          Haven't given the rear end another thought since...
          My experience...
          • Like Like x 2
          • Agree Agree x 2
          • 70aarcuda
            70aarcuda Master Hoader of SBM FABO Gold Member
            16,280
            4927
            Jan 16, 2005
            las vegas
            Local Time:
            2:14 PM
            The ring gear in a 8 3/4 rear is the weakest link.....if you are racing...sooner or later it will eat teeth.....
            • Agree Agree x 3
            • A body
              A body SLO-KID
              1,287
              456
              Jun 24, 2013
              AZ
              Local Time:
              2:14 PM
              no.... because I removed it and upgraded
              • Like Like x 1
              • Agree Agree x 1
              • TheGrateRonzini
                TheGrateRonzini FABO Gold Member FABO Gold Member
                905
                750
                Oct 25, 2017
                Western New York
                Local Time:
                5:14 PM
                As stated above. You are good til you hook. Then you start breaking stuff. If you are boiling the tires every time you give it gas, that’s not usually a problem. But big sticky tires leaving at high RPM will make quick work of it.
                • Agree Agree x 4
                • 33IMP
                  33IMP Well-Known Member
                  848
                  860
                  Jul 3, 2020
                  Taxifornia, soon 2b arizona
                  Local Time:
                  2:14 PM
                  Yes, a stock 489 will live just fine.......as long as you never, EVER put good tires on it. Put hard-ass T/A radials on it, it will live forever. Especially if you continue to use a no-stall-speed converter, and no gear in the back.
                  There is NO way i would spend $1500 on a 8 3/4 center, if i had 700 hp. A new strange 60 is only about $700 (?) more, and you can turn your 8 3/4 before you break it, to recoup some of the cost of the 60. But if you keep that nothing converter, you probably wont need one.
                  • Agree Agree x 3
                  • Like Like x 1
                  • j par
                    27,548
                    14963
                    Jul 2, 2014
                    Portland Oregon
                    Local Time:
                    2:14 PM
                    As a side note I had $1,200 total into my 8 3/4 that blew up and $1,200 total into the Dana 60 that now reside underneath the Duster..
                    • Like Like x 5
                    • Agree Agree x 1
                    • Jadaharabi
                      Jadaharabi FABO Gold Member FABO Gold Member
                      8,719
                      9664
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      4:14 PM
                      Buy a dana from Dr Diff. 1977 489 with 4.56 gears in a 340 6 pac 69 4sp Dart, (12.20 et)split the crush sleeve like a laser cut it.
                      • Like Like x 2
                      • 33IMP
                        848
                        860
                        Jul 3, 2020
                        Local Time:
                        2:14 PM
                        I will also bet that you will hate your car with a big horspower small block, and no converter and no gear. If i had a 650 horse smallblock, 4000 to 4500 converter, and 3.91 gear would be a minimum.
                        (Just the opinion of a guy with a 550hp big block with a 5000 stall, 3.91 on the street).
                        Edit: this post is completely irrelevant, if you made 650 with a blower, a turbo, or nitrous, i assumed n/a, and you know what happens when you assume!
                      • flyfish
                        flyfish C8H18+N2O = :-D
                        2,243
                        830
                        Apr 16, 2007
                        Indy
                        Local Time:
                        5:14 PM
                        I'm confused on many fronts....why do you want 3.23 gears and a 2500 converter behind a "650hp" engine (I can't think of any).
                        Also, how did you come up with "650hp"?.....kinda smells like a big scoop of Hotrod magazine, lack of sleep and a "3/4 race cam" = 650hp?!?!?!?
                        • Agree Agree x 5
                        • Like Like x 2
                        • 70DusterBob
                          713
                          167
                          Feb 20, 2016
                          Texas
                          Local Time:
                          4:14 PM
                          Thanks, the way you put that is kinda funny, I hope you were trying to be funny and serious at the same time. See further all-in-one reply farther down.
                          • Like Like x 1
                          • Disagree Disagree x 1
                          • 70DusterBob
                            713
                            167
                            Feb 20, 2016
                            Texas
                            Local Time:
                            4:14 PM
                            It is not for a strictly race car. It is a street/strip car. I only have race radials on it so I can drive it on the street.
                            I am working on a project that I can't mention that will boost the hp from 500 to about 625, (I'm hoping) 650 is for room and I want it to be able to hold 700hp because I don't want to come "ANYWHERE NEAR" the breaking point! Hooking up with slicks is what one of my friend said about breaking a diff. I don't think I will be hooking up, but I am concerned about low end torque. Is that much of a factor if I don't hook up off the line but say 50 feet down the track or so? I don't know for sure where it will hook but just guestimating.
                          • fratzog lover
                            fratzog lover Well-Known Member
                            15,322
                            13969
                            Jun 7, 2013
                            Maple Shade New Jersey
                            Local Time:
                            5:14 PM
                            The lower(numerically) you go, the more stress on the ring gear. 3.23 or 2.76 will break before a 3.91 or 4.10
                            • Agree Agree x 4
                            • 70DusterBob
                              713
                              167
                              Feb 20, 2016
                              Texas
                              Local Time:
                              4:14 PM
                              Hey Mike,
                              I appreciate the lead, but very Dana that Strange makes is an S60, could you be more specific? I will call them when they open to see what they can recommend for me, but like the saying goes, better safe than sorry. If you know of a particular Dana they sell, please let me know. Thanks
                            • Ottmundr
                              Ottmundr 68 Fastback
                              7,616
                              11768
                              Oct 5, 2012
                              Sonoma
                              Local Time:
                              2:14 PM
                              Just get the s60 from Dr. Diff like mentioned above.
                              and you may want to re-think that torque converter and the highway gears.
                              and go back and look at the pictures jpar put up.
                              Or, just say fuckit and get a trailer because you're gonna need it when you do destroy that 8 3/4, just like that printer in Office Space.
                            • 70DusterBob
                              713
                              167
                              Feb 20, 2016
                              Texas
                              Local Time:
                              4:14 PM
                              I don't want to race all the time. Should have mentioned that. It is a street/strip car, I only want to test improvements that I make on the strip, but it will mainly be a highway car since I don't drive it in the city if I can at all help it. I understand the lower the # of the gear ratio, the more stress they take. But it is hard to baby a car and race it at the same time, I need an all around diff that will hold under track conditions. The engine makes 500hp, but I plan on adding to that. Dana sounds like the way to go.
                              Thanks
                              • Agree Agree x 1
                              • fratzog lover
                                15,322
                                13969
                                Jun 7, 2013
                                Local Time:
                                5:14 PM
                                It's a shame we all cant have a GV overdrive. They cost a wee bit of money!
                                • Like Like x 1
                                • B3422w5
                                  B3422w5 Well-Known Member
                                  1,511
                                  1512
                                  Feb 9, 2017
                                  Portage michigan
                                  Local Time:
                                  5:14 PM
                                  Sounds like a torque storm type thing you have going on.
                                  The rear needs swapped with any “ real” power
                                  • Agree Agree x 1
                                  • 70DusterBob
                                    713
                                    167
                                    Feb 20, 2016
                                    Texas
                                    Local Time:
                                    4:14 PM
                                    Looking at Dr Diff S60, the options are limited, I can't get Race Axles and go without a spool which I don't want. I want the Trac-Lock, but is the Trac-Lock going to hold up under track conditions? Also the Pro-Gears need a Spool, which I don't want, but I want strong gears, will the stock gears hold up under race conditions as long as I don't hook up with slicks?
                                    So, w/o the race axles, without the spool, with the trac-lock, stock Dana Gears, will be about $2,500 after taxes. Someone above said they found one for $1,200. I'm guessing that was used?
                                  • 70DusterBob
                                    713
                                    167
                                    Feb 20, 2016
                                    Texas
                                    Local Time:
                                    4:14 PM
                                    I heard that!!!
                                  • 33IMP
                                    848
                                    860
                                    Jul 3, 2020
                                    Local Time:
                                    2:14 PM
                                    Slicks can spin a little at the strip, and still recover and post a decent time. Drag radials only work well as a dead hook. If they spin, the only way they recover is to completely chop power ( also, NOT good in first gear for your 727), therefor drag radials are HARDER on the drivetrain than slicks!
                                    The $1200 dana above was built from a truck dana that probably had thicker axle tubes and floater axles. So, it was narrowed, had new axle ends installed, new custom axles, and an unknown gear and suregrip, or spool, installed. Thats how to save half the cost of a new strange (dr diff) 60.
                                    Just about any guts in a 60 will live forever behind a small block. I personally would choose a 35 spline clutch suregrip. They have gone billions of miles in trucks. I dont trust the gear style, i have heard too many complaints.
                                  • 70DusterBob
                                    713
                                    167
                                    Feb 20, 2016
                                    Texas
                                    Local Time:
                                    4:14 PM
                                    Where did you get your $1,200 Dana??? Dr Diff and Strange want like 2X that... Yikes!
                                    • Like Like x 2
