will flaming river 1540 16:1 box fit 1965 cuda?
Suspension, Steering and Chassis
  1. cudajaun
    cudajaun Member
    8
    0
    Aug 17, 2012
    PA
    Local Time:
    5:34 PM
    Hey all,
    i've got a 65 S cuda that i built back in the 90's, with a 5.5 lock-to-lock manual box. i'm also running '68-'70 340 exhaust mainfolds, which is already real close to the steering collar bolt head. i've read all the threads re the FR 1540 box, and have seen that some feel it will direct fit pre-'66 a bodies, but can't find a thread where someone actually did it. just called Flaming river, and tech guy said there must be something different with pre-'66 cars, but he didn't know (???). jegs and summit say '66 and up.
    has anyone actually direct fitted one to a pre-'66 a body, or know where someone has? if so, i'd appreciate input on how it went, and whether any mods were needed. from what i've read, the only possible glitch is the spline for the pitman arm, but not the arm itself.
    thanks for any advice! Brian
  2. 72BBSwinger
    72BBSwinger Well-Known Member
    2,043
    61
    Feb 23, 2011
    nebraska
    Local Time:
    4:34 PM
    Pretty sure all Mopars from 62+ use the same box.
  3. cudajaun
    cudajaun Member
    8
    0
    Aug 17, 2012
    PA
    Local Time:
    5:34 PM
    well i would agree for '63 -'66, but don't want to get one under an assumption. anyone know for sure? hard to believe FRiver would advertise '66 as the cutoff year incorrectly, missing out on 3 yrs of a body sales for no reason...
    thanx again
  4. 72BBSwinger
    2,043
    61
    Feb 23, 2011
    nebraska
    Local Time:
    4:34 PM
    Well on my Borgeson it shows that it fits all Mopar cars from 62-72 with small sector shaft. I replaced the Flaming River box with this box. Yep I would venture to guess you'll be fine.
  5. C130 Chief
    C130 Chief Mechanical Genius
    3,055
    190
    Nov 23, 2005
    Boise, ID
    Local Time:
    3:34 PM
    ALL early A-body Pittman arms are small spline. Also, the early cars had smaller box mounting bolts. So, if the Flaming River box has the small spline sector shaft it will work. I would bush the mounting holes down to the smaller size, but it's not absolutely necessary.
  6. cudajaun
    cudajaun Member
    8
    0
    Aug 17, 2012
    PA
    Local Time:
    5:34 PM
    thanks fellas i feel better now about ordering one.
