Rapid Robert
I have my eye on some 340 ex manifolds. If good what gaskets do I buy? thank you for your time. RR
Maybe, depends on the heads themselves.
Start reading.
Magnum Heads On 340
340 exhaust manifolds
Some older threads mention EQ heads but they are referring to the old New Zealand-cast heads, not the current China-cast heads.
340 manifolds and Magnum heads
@DionR
Personally, even though they don't flow quite as well as the 340 manifolds, I think 318 manifolds' ports match the Magnum port size better and are more likely to seal well.
But then again, nothing matches a Magnum port as well as a Magnum manifold. And you know they'll seal.
