Will this fit a '75 duster ?
grassy
Nova Scotia
Hi. I an looking to buy a 1970 challenger black steering wheel in the clssified forum.
Will this fit ?
Thanks.
Grassy
Get the column adapter with it if you can. The spline count is the same. It may be too long to comfortably fit an A-Body unless it's a Tuff wheel.
It should bolt up. It is a three bolt wheel. Have to ask him what the diameter is and check it with your wheel. find out what the dish is too. If it is less you may need to run a spacer or bend the turn signal lever if it does not have as much as the wheel you have now.
Wow..too complicated for me and the car in storage. I thought if it was just a quick flip I would do it..I appreciate all the help....soon I am going to actually the work I have been talking about.
ian.
