Will this pulley fit?
Dfnsmn34
Margarita Mike
Ewa Beach
Aloha! I have a original (Right) style Federal pump that has the press on pulley. Can I use that pulley on the new rebuilt pump that has the threaded (left) type shaft? The shaft appears the same diameter.
Do I just need to get a bolt and washer and install?
see photo...
Mahalo!!!!
1966 barracuda 273
No one knows? hmmm...well...I guess i'll pull the pulley off...and try my luck. Mahalo!
........How did u make out.........new shaft isnt tapered so it looks like it should go, unless shaft size is different............kim.......
It fit perfect. Pressed on. Do I even need to put a bolt in it? I guess i could just to keep grime out...
still getting the air out of the system so it's a little stiff more driving should help it i think.
