Windage tray not in engine
Small Block Mopar Engine
  1. Byron Gray
    Byron Gray Well-Known Member
    72
    14
    Sep 19, 2016
    Belfair Washington
    Local Time:
    1:26 AM
    I got a 78 318 put of a Chrysler Lebaron that I'm freshening up for my 67 Dart. I noticed when I took it a part it did not have a windage tray in it and the main cap bolts do not have that part on the head to bolt a tray in.
    I noticed someone had been inside that engine before it has .040 pistons. Could that engine have came from the factory with out one? Or who ever rebuilt it before removed it.
    I understand what the tray dose for the oil and since this is going to be just a stock rebuild and be a highway cruiser and nothing crazy would it really be worth getting one? I can find a tray easy but what about the main cap bolts that the tray bolts thread into where would I find those?
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    52,866
    17853
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    3:26 AM
    318's didn't come with windage trays...
    340's did...
    You could always install one if you want to... Just get the windage tray and mounting bolt kit...
    • Agree Agree x 3
    • Thanks! Thanks! x 1
    • Byron Gray
      72
      14
      Sep 19, 2016
      Belfair Washington
      Local Time:
      1:26 AM
      ok thanks thats good to know now. my 360 in my duster has a tray also so only 340 and 360s get them.
    • Jadaharabi
      Jadaharabi FABO Gold Member FABO Gold Member
      7,207
      7730
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      3:26 AM
      360 2bbl did not have a windage tray.
      • Agree Agree x 2
      • flyfish
        flyfish C8H18+N2O = :-D
        1,984
        555
        Apr 16, 2007
        Indy
        Local Time:
        4:26 AM
        You don't need it, but if it makes you feel better you can spend hours/days pulling the engine and installing one.
        For what its worth, my low 10 second small block doesn't use one...neither did my mid 10 second motor before that...or the 11 second motor before that....or the 13 second motor before that....or the 14 second motor before that........or the 16 second motor before that....or the Fred Flintstones motor before that, lol.
        • Like Like x 7
        • Agree Agree x 2
        • toolmanmike
          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
          49,575
          34366
          Jan 18, 2006
          Iowa
          Local Time:
          3:26 AM
          You may see it on a dyno but your seat of the pants dyno will never catch it.
          • Like Like x 1
          • Agree Agree x 1
          • Darter6
            Darter6 Well-Known Member
            4,125
            1376
            Jan 16, 2008
            Nevada
            Local Time:
            1:26 AM
            Years ago Mopar Muscle did a dyno test and they concluded that a windage tray was good for over 6,000 rpm.Below that showed no real value.
            • Thanks! Thanks! x 2
            • Like Like x 1
            • 65 Dartman
              65 Dartman FABO Gold Member FABO Gold Member
              11,252
              2905
              Sep 24, 2006
              Strasburg, VA
              Local Time:
              4:26 AM
              Because I had an extra windage tray, I installed it in my 273/235 Commando engine going in my 65 Wagon. 20-30 years from now someone who might disassemble the engine will see this and claim all 273/235 Commando motors had a windage tray LOL!
              • Like Like x 5
              • Agree Agree x 1
              • Oldmanmopar
                Oldmanmopar Going left turning right FABO Gold Member
                8,197
                4330
                Jan 8, 2009
                Danielsville Pa.
                Local Time:
                4:26 AM
                I have the bolts and the tray from 340's. To install it on a 318 you have to use Hemi Head bolt washers under the bolts. I have those also. You don't really need a windage tray on your motor unless you plan on performance add ons. The 360 tray is totally different then a 340 and do not interchange due to the caps.
                • MOPAROFFICIAL
                  MOPAROFFICIAL FABO Gold Member FABO Gold Member
                  5,739
                  4694
                  Jun 1, 2016
                  Beach
                  Local Time:
                  1:26 AM
                  When I thought I couldn't laugh any more...I read... "flintstones"...
                  Thank you.
                  • Agree Agree x 2
                  • pittsburghracer
                    pittsburghracer FABO Gold Member FABO Gold Member
                    3,431
                    6201
                    Apr 20, 2016
                    Freeport, PA.
                    Local Time:
                    4:26 AM
                    I gave my last one away to a friend that needed it. Total waste of time and energy rounding up the parts to put one in.
                  • MOPAROFFICIAL
                    5,739
                    4694
                    Jun 1, 2016
                    Beach
                    Local Time:
                    1:26 AM
                    Been said if you run a deep pan..they're not necessary. Crank Scraper wouldn't be a bad idea, or would be a better one.
                    • Like Like x 1
                    • Jadaharabi
                      7,207
                      7730
                      Jan 8, 2016
                      Peoria, Illinois
                      Local Time:
                      3:26 AM
                      To clear up the 360 windage tray. There was 3 trays
                      #1 for the 340
                      #2 for the 360
                      #3 was a later tray with slotted or opened up mounting holes that work on both the 340 & 360
                      • Agree Agree x 1
                      • sireland67
                        sireland67 Well-Known Member
                        8,997
                        3159
                        Oct 27, 2010
                        WV
                        Local Time:
                        4:26 AM
                      • pishta
                        pishta I know I'm right....
                        17,334
                        6935
                        Oct 13, 2004
                        Tustin, CA
                        Local Time:
                        1:26 AM
                        someone at a show once told me the 360 tray was the one to get for a stroker app. Not sure if anything but the bolt spacing was different?
                      • Byron Gray
                        72
                        14
                        Sep 19, 2016
                        Belfair Washington
                        Local Time:
                        1:26 AM
                        Since the engine didnt come with one I'm not going out of my way to get one. I'm keeping this engine as cheap as possible because it's not going to stay in the car long. I got a gen 3 5.7 I'm going to build the 318 is temporary so the car isnt just sitting not being used
                        • Like Like x 1
                        • MOPAROFFICIAL
                          5,739
                          4694
                          Jun 1, 2016
                          Beach
                          Local Time:
                          1:26 AM
                          There is one 'hopefully unneeded' benefit..the milodon windage tray i decided to used sure saved my 300.00 something dollar milodon pan when the piston disintegrated and the cylinder wall shattered. Looked like it was shot at.
                          • Like Like x 1
