swing69
fightin' socialism
1965 Barracuda. How do you install the soft rubber window seals in the rear qtr windows? picts would be helpful too.
Also: how do you removed the pins from the steering column connector??? I need to put the new wires from the new signal assembly into the old white connector.....so it can mate with the dash harness.
Thanks!
Thanks!
