Window slide? 68 Fastback
Mopar Body and Trim
  1. harrytoes
    harrytoes Well-Known Member
    89
    10
    Jun 7, 2005
    Encinitas, Ca
    Local Time:
    8:01 AM
    Trying to put the glass back in. I think I’m missing a piece. I believe the white pieces are what attaches it. Is it just those pieces or is there something else that goes on the glass?
  2. harrytoes
    89
    10
    Jun 7, 2005
    Encinitas, Ca
    Local Time:
    8:01 AM
    I put them on the glass. It just seems like something is missing on the glass?
  3. gdrill
    gdrill OK, now what??? Staff Member FABO Gold Member
    6,398
    5974
    Sep 26, 2011
    Just North of Montana
    Local Time:
    9:01 AM
    Those and possibly a "plastic sleeve"' My Coronet uses these as well and has a plastic piece that runs from top to bottom. It is sort of a sleeve that goes over the edge for lack of a better description. It is held on by those clips. It may actually be weatherstrip on a Dart, but on the Coronet it was merely a piece of plastic.
    • Like Like x 1
    • gdrill
      6,398
      5974
      Sep 26, 2011
      Local Time:
      9:01 AM
      It kind of shows it here.
      • Like Like x 1
      • harrytoes
        89
        10
        Jun 7, 2005
        Encinitas, Ca
        Local Time:
        8:01 AM
      • gdrill
        6,398
        5974
        Sep 26, 2011
        Local Time:
        9:01 AM
        Mine were old and clear plastic but those sound like what I'm describing. They "include" plastic clips and pins.
      • RAT ROD AL
        RAT ROD AL FABO Gold Member FABO Gold Member
        1,039
        841
        Jan 18, 2013
        St. James City. FL.
        Local Time:
        11:01 AM
        Maybe you can see the clear plastic strip on the edge of the glass. Those little plastic slider pads hold them on as previously stated. Once the window is installed you can't see em. You could probably do without em.
        • Agree Agree x 1
        • loganscuda
          loganscuda DON’T reMember
          1,599
          1253
          Jul 15, 2010
          san antonio
          Local Time:
          10:01 AM
        • Murray
          Murray FABO Gold Member FABO Gold Member
          922
          479
          Apr 19, 2010
          San Jose, California
          Local Time:
          8:01 AM
          Comes as a kit. Buy it. What is now a clear plastic guide w/ pins, used to be a black fuzzy when new. The new plastic guides make it water tight.
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • harrytoes
            89
            10
            Jun 7, 2005
            Encinitas, Ca
            Local Time:
            8:01 AM
            Any idea where I can get it?
          • DrCharles
            DrCharles Well-Known Member
            438
            157
            Jun 7, 2012
            West Plains, Mo.
            Local Time:
            10:01 AM
          • retroron
            retroron FABO Gold Member FABO Gold Member
            607
            388
            Apr 9, 2014
            Livermore Calif
            Local Time:
            8:01 AM
            I've got spare set at half price, plus shipping, PM me.
          • Cuda Al
            Cuda Al Well-Known Member
            712
            626
            Oct 21, 2007
            Lompoc, CA
            Local Time:
            8:01 AM
            Typically they sell the weatherstrip piece with the sliders.
            They are sold uncut and unpunched.
            They were cut to length and holes punched.
            Alan
            • Murray
              922
              479
              Apr 19, 2010
              Local Time:
              8:01 AM
              Alan, nice pics. Am currently working on my glass. Do those holes in the sliders need to be punched in the new sliders?
            • DrCharles
              438
              157
              Jun 7, 2012
              West Plains, Mo.
              Local Time:
              10:01 AM
              You do have to punch at least the middle hole so the shoulders on the nylon sliders can go in (and the pin connecting them)...
              The originals on my '72 did not have all three holes punched, but the sliders (either from wear or design) are slightly thinner too. If I do this again I'll punch three holes.
            • gdrill
              6,398
              5974
              Sep 26, 2011
              Local Time:
              9:01 AM
              This has been an educational thread. I will now order the new seals for my car. I wondered if they could be acquired. Thanks guys.
            • Murray
              922
              479
              Apr 19, 2010
              Local Time:
              8:01 AM
              Thanks. Would a regular round hole punch work or should the holes be square?
            • Cuda Al
              712
              626
              Oct 21, 2007
              Lompoc, CA
              Local Time:
              8:01 AM
              The weather strips are available and not cheap, $80ish, the profile may be different. They are universal to all Mopars that need them so they will need to be sized and punched. I used a desktop palm hole punch, you need to pinch the trim so both sides can be done at the same time. The hole size needs to be matched to the sliders.
              Alan
              • Thanks! Thanks! x 2
              • RPM440+6
                RPM440+6 Well-Known Member
                161
                66
                Dec 1, 2013
                Georgia
                Local Time:
                10:01 AM
                If your should purchase the reproduction glass channel runs, expect a battle. They are very fragile and easily torn. The OEM runs fit much better, but have been discontinued. If you do find a OEM pieces, they are bringing $200 to $600 per pair.
                If you decide to use the reproduction runs, reuse your old nylon "H-Pin" slides. The reproduction "H-Pin" slides are a bit too thick. You can slightly sand them down to help some of the issues.
                • Thanks! Thanks! x 3
                • Agree Agree x 1
                • harrytoes
                  89
                  10
                  Jun 7, 2005
                  Encinitas, Ca
                  Local Time:
                  8:01 AM
                  So I had some credit at Classic Industries so i bought their glass channels. WTF?? 99 bucks for for that? Anyways, it came with the h pins and the black channel. Still confused how this all goes together. What needs to be hole punched? What attaches with the h pins? How much of the black channel needs to be trimmed? Thanks for the help.
                • Cuda Al
                  712
                  626
                  Oct 21, 2007
                  Lompoc, CA
                  Local Time:
                  8:01 AM
                  Look at the pictures i posted above (post #13), cut that same notch at one end (top), keep in mind a left and right as they are curved with the glass.
                  Test fit the weatherstrip and glass in the frame, If I recall the weatherstrip goes to the to of the glass (ignoring the notch in the glass).
                  Make sure you slide the weatherstrip all the way up, not the placement of the glass in the weatherstrip (the sides of the weatherstrip should go to the top off the glass ignoring the notch)
                  Once you confirm that then remove them from the frame and put the weatherstrip on the glass and note the hole locations.
                  I was able to pinch the weatherstrip and punch both sides at once.
                  Trim the bottom of the weatherstrip at the bottom of the glass.
                  Alan
