Windscreen Wiper Motor - Removal & Replacement
Mopar Body and Trim
  1. Rob Mack
    Rob Mack New Member
    3
    0
    Jan 29, 2021
    Sunshine Coast, Queensland, AUSTRALIA
    Local Time:
    11:06 PM
    I have a 1971 Chrysler Valiant Regal (Australian), on the same design (some variation) as the 1970 Plymouth Valiant (USA). The wiper motor is located on the outside fire wall (not under the dash like some US models), so it is easy to get to. I want to replace it with a cleaned up reconditioned unit, but I am hesitant to undo the holding bolts because I don't want to be disconnecting internal parts that maybe difficult to reconnect. Has anyone done this replacement who could give me an idea on what is involved??? ROB.
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    60,353
    26494
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    7:06 AM
    There is a clip that holds the linkage to the wiper motor under the dash that you have to disconnect... The rest is done from under the hood - disconnect the wiring harness, and then loosen the attaching bolts/nuts and remove it...
  3. moparmat2000
    moparmat2000 FABO Gold Member FABO Gold Member
    20,153
    9484
    May 13, 2010
    Grand Tetons
    Local Time:
    7:06 AM
    If the crank arm on the motor wont clear the hole in the firewall to get it out. Remove the nut on the motor shaft, and remove the crank arm, then take the motor out.
  4. Joey4speed
    Joey4speed FABO Gold Member FABO Gold Member
    1,602
    1297
    Jul 17, 2018
    Coastal NC
    Local Time:
    8:06 AM
    If your clip looks like this?
  5. CFD244
    CFD244 FABO Gold Member FABO Gold Member
    1,225
    1275
    Sep 7, 2017
    Northern Ontario, Canada
    Local Time:
    8:06 AM
    I'd mark the shaft and the arm so that it doesn't go onto the new motor 180* off.
    • Agree Agree x 1
    • RedFish
      RedFish Well-Known Member
      25,019
      3717
      Sep 5, 2007
      Local Time:
      8:06 AM
      Wiper motor is right behind radio and climate controller. Remove either and you'll get to the nut with long extension. Always run the motor at reinstall, turn it off and confirm it parked before attaching the linkage with wipers in park position.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • 4spdragtop
        4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
        32,446
        13557
        Aug 28, 2009
        Wasting time here
        Local Time:
        7:06 AM
        • Lord Sparky
          Lord Sparky Well-Known Member
          670
          502
          Dec 2, 2019
          Carlsbad, California
          Local Time:
          5:06 AM
          Take photos of it all first inside and out. My inner clip fell off and it was a little hard to remember how it was.
          • Agree Agree x 1
          • Rob Mack
            Rob Mack New Member
            3
            0
            Jan 29, 2021
            Local Time:
            11:06 PM
            Thanks to all you blokes for the heads up on this query....very much appreciated and I will take on board all details...her goes.....ROB
          • Rob Mack
            Rob Mack New Member
            3
            0
            Jan 29, 2021
            Local Time:
            11:06 PM
            Thanks to all you blokes for the heads up on this query.....very much appreciated and I will take on board all details.....here goes.....ROB
