Wiper motor removal - help
Robco1
Member
Gillette, WY
I am trying to remove the wiper motor from my 67 Barracuda and the thing will not budge. I have removed the wiper arm linkage and bolt from the motor shaft, and the three nuts holding the motor to the firewall. Is it the seals / gaskets that is keeping it on? The engine is installed so I don't have much room below the wiper motor itself.
Thanks.
The mounting studs have shoulders that fit tight in the holes. Plus the stuck seal. Bump it around in different directions until it loosens.
