1. wheelsport
    wheelsport Well-Known Member
    141
    95
    Jan 21, 2019
    Vancouver, Washington
    Local Time:
    6:40 AM
    My '65 came with variable speed wipers and the switch has problems. Variable switches are a little costly and since I rarely drive in the rain I am wondering if a single speed switch will work in my car?
  2. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    51,578
    20588
    Oct 14, 2010
    Idaho
    Local Time:
    6:40 AM
    I believe you can use a 2 speed switch, but not really familiar with pre-67
  3. orangemonster
    orangemonster Member
    17
    3
    Feb 5, 2021
    Utah
    Local Time:
    7:40 AM
    Mine was a variable speed. I Took it apart and cleaned the Contacts and used some dielectric grease.Nothing was broke or cracked. Good to go.
    • Like Like x 1
    • cudamark
      cudamark FABO Gold Member FABO Gold Member
      9,131
      1552
      Mar 14, 2009
      San Diego
      Local Time:
      6:40 AM
      The wiring is a bit different between the single speed and the variable speed....both on the switch and the motor. I'm sure you could mess around and find a way, but, the wipers will run full blast all the time. Not worth the trouble in my book. Run a wanted ad here on FABO with the part number off your old one. Someone's bound to have a good used switch.
    • wheelsport
      141
      95
      Jan 21, 2019
      Local Time:
      6:40 AM
      Thank you Cuda - that's what I need to know. By the way I found a working variable switch for $50.
    • cudamark
      9,131
      1552
      Mar 14, 2009
      San Diego
      Local Time:
      6:40 AM
      Great, that's the best way to go. It will save you a lot of grief down the road. Just make sure the motor is properly grounded and the pivots move freely while you're at it.
