phatty67
Member
im looking for a wiring diagram for the ignition circuit for a 67 Cuda 273.
im getting rid of the point distributor and putting in aftermarket electronic . want to use as much of the stock wiring as i can
I thought a megaskillion times.Posted this a skillion times. ...
The blue "run" wire GOES DEAD during cranking. There's an additional wire that comes from the key and goes to the coil+ side of the ballast, this is the coil resistor "bypass" circuit, and IS THE ONLY power hot during "cranking"
Why? Dwell is more consistent from the git go with the points. People say starting takes more turns with electronic.im getting rid of the point distributor and putting in aftermarket electronic . want to use as much of the stock wiring as i can
