This is incredible. One off DOHC conversion, 3 valve / cylinder, Top longintudinal girdle to hold the block together, and 5 bolt main--original block is 3 bolt main, so two added mains.
I don't know if you caught it, but the main reason they are doing the sunken chambers is that the race body changed the rules, and the block must maintain stock block height. They wanted shorter rods for better rod/ stroke ratio.I saw this episode last night, very entertaining. Reminded me of an engine I saw on an engine masters competition (before the YouTube show) where I think a SBM was used (maybe poly 318?) where they sunk the head into the block in the same way. It's one of the most ingenious things I've seen to an engine
I think this guy did it earlier and much more complicated with custom heads but I love how they modified the block in every way possible to get the most out of it
Yeah I caught that, but the secondary benefit to doing this is being able to make completely custom intake/exhaust runners. He talked about making his ideal short side radius on both sides of the intakeI don't know if you caught it, but the main reason they are doing the sunken chambers is that the race body changed the rules, and the block must maintain stock block height. They wanted shorter rods for better rod/ stroke ratio.
