Hankrebel
I bought what I thought were rear 10" drums from Rock Auto.
All brake hardware and shoes installed with no issue.
Even the drums went on and were flush at the hub and spin freely.
I put the wheels on and drop her off the jackstands.
Put her in reverse and she wont budge an inch.
I gave it a little gas and I can hear the drums rubbing against something.
Jack her back up and remove the wheels.
Dums pull off fine but I can see where the drum lips is up against the backing plate and grinding/rubbing.
I can also see the rub marks on the drum lip and inner surface.
What gives? I measured the the old drums total width - 2 2/4
I measured the new drums total width - 3 1/4
You can see from the pictures the drums are a lot larger than the old ones.
By looking at how much is rubbing, I can probably get a shop to lathe off about 1/8 inch on the lip and inner surface. But if that doesnt work, Rock Auto wont take the drums back.
Any suggestions?
Any suggestions?
