Sportfury70
Active Member
I have a 1970 Satellite I just swapped a 8-3/4 into (original 8-1/4). You guys have been a great help with figuring out my magnum swap, so figured I’d ask here.
I pieced the rear together and up until today it had turned out great. Correct housing, 11” brakes, 741 with 3.55 sure grip, etc. I got the axle shafts and brakes from a guy who said they were from a 70 RR, and stated they were the correct 29-3/16 length. They have the tapered bearings.
Attempting to set the end play has been super frustrating, so I pulled the shaft and found it measured out to just a hair under 29” tip to outside flange. NOT what it’s supposed to be. I believe they probably came out of a 65-67 b body.
Does anyone know, since green bearings eliminate the adjuster, can I use these slightly short shafts with those without having to source new shafts?
I can’t see a reason why not since you’re supposed to eliminate the center spacer with the green bearings anyway, but I’d like some opinions to make sure.
