WTB 65 4-Barrel Intake Manifold 273
Thanks Val, not doing a "numbers resto" If I can't find a 65 intake, how do you
adapt to the later yr??
Just need to "waller out" the holes a bit...the early ones are just a bit different angle than the late ones...other than that, they're pretty much the same intake. You'll also need a 4 barrel throttle bracket as the 4 barrel carb (Carter/Eddy or Holley) is wider than a 2 bbl, and 4 barrel kickdown linkage, although the 2 bbl stuff can be modified (extended) to work.
You can do the same to aftermarket intakes (Performer,LD4B, SP2P, etc) as well, in case you don't find a stock one, as long as they have the smaller 273/318 intake ports.
Cheers.....
