nm9stheham
My son and I finally got the new Hughes rockers installed and fired up about 3 weeks ago, and after about 3 seconds, there came a serious BANG BANG BANG BANG...... that was at engine speed. It sounded like a piston hitting the head or a valve.
A quick shut down, and some diagnosis (when we weren't traveling and working like maniacs) and close inspection of the valve train, it became clear something was in a cylinder jamming a piston; when turning by hand, the crank came to a stop when cylinders 8 & 5 were at TDC. I had felt a small tight spot in the rotation when we adjusted preload but this time is was a hard stop.
Well, here it is; it was on the lower side of the piston, in the small quench gap on the spark plug side of the Edelbrock RPM performer. I cannot for the life of me figure out what this is.... it has a sharp hardened point, and is split, as if it is intended to wedge into something. It is almost like a tool centering bit... could it be from the Serdi machine that was used to open under the seats??
And then comes the question of how it could be in there 1000 miles and not ever be heard......
