"X" or "TA" heads???
Mopar General Discussions
  1. Alberto
    Alberto Member
    22
    18
    Nov 6, 2008
    Sarasota, FL
    Local Time:
    9:11 AM
    Hey Guys,
    I want to properly identify these heads. I will give all the numbers I found on the head.
    3418915 B. Then AAWJ 360. Another tiny plate that is screwed to the head "01090" . There are also several big "U"s stamped on it. It does have 2.02 / 1.60 valves. I looked on three different cast number charts and they all say that they are "TA".
    The block is not a "TA" block, it is 2780930, with a 10/5/69 date code.
    Are "TA" heads worth more than "X" heads?:popcorn:
    THANK YOU everyone!!!:thankyou:
    AL
  2. 70aarcuda
    70aarcuda Master Hoader of SBM FABO Gold Member
    16,012
    4644
    Jan 16, 2005
    las vegas
    Local Time:
    7:11 AM
    ok....J U O heads use the same casting number as the TA head.....but the TA head has the intake pushrods drilled at an angle....and only use TA rockers.....
  3. gm1236
    gm1236 Well-Known Member
    157
    64
    Aug 3, 2013
    Massachusetts
    Local Time:
    10:11 AM
    T/A heads have offset intake pushrod holes. Some have a U between the plugs. All had 2.02 valves and some J heads had 2.02 valves in 71 340’s.
    • Agree Agree x 1
    • 4spdragtop
      4spdragtop CONGRATS NORTH AMERICA! FABO Gold Member
      30,410
      10966
      Aug 28, 2009
      Wasting time here
      Local Time:
      9:11 AM
      Pics
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      5,758
      4075
      Nov 12, 2004
      PA
      Local Time:
      10:11 AM
      I saved this screen capture quite a while ago, I hope it helps;
    • Jadaharabi
      Jadaharabi FABO Gold Member FABO Gold Member
      8,312
      9217
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      9:11 AM
      Did the heads have adjustable rockers or stamped steel?
    • Alaskan_TA
      5,758
      4075
      Nov 12, 2004
      PA
      Local Time:
      10:11 AM
      That is not a 'tell' in itself.
      Adjustable 273 rockers fit X & normal 915 heads, 974s too.
    • Alberto
      Alberto Member
      22
      18
      Nov 6, 2008
      Sarasota, FL
      Local Time:
      9:11 AM
      Man you all are quick!!:thumbsup:
      The push rod holes not offset, so "X" head it must be. I will post a pic tomorrow though.
      THANKS AGAIN!!!!!!
    • Jadaharabi
      8,312
      9217
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      9:11 AM
      If they are using stamp steel rockers, we know they are Not TA heads.
      If they have adjustable rockers then we look farther at the rockers.
    • Jadaharabi
      8,312
      9217
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      9:11 AM
      Not an X head. It's a 2.02, 915 U head.
      Nice heads by the way.
      • Like Like x 1
      • Alaskan_TA
        5,758
        4075
        Nov 12, 2004
        PA
        Local Time:
        10:11 AM
        If it / they have the cast in U they are 915 heads.
        You also mentioned the 915 casting number.
        Not all 915 castings are T/A heads.
      • Alberto
        Alberto Member
        22
        18
        Nov 6, 2008
        Sarasota, FL
        Local Time:
        9:11 AM
        The heads have stamped steel rockers..
      • MoparMike1974
        MoparMike1974 FABO Gold Member FABO Gold Member
        2,888
        2144
        Jun 16, 2017
        Maryland
        Local Time:
        10:11 AM
        I have had TA heads with U casting and also O. TA heads were 360 heads machined for offset pushrod to give more meat for porting. X heads would have an X on them, pretty simple.
        "Are "TA" heads worth more than "X" heads?" Yeah that is an understatement.
      • Alberto
        Alberto Member
        22
        18
        Nov 6, 2008
        Sarasota, FL
        Local Time:
        9:11 AM
        Damn, this is a bit confusing. So what is the difference between the "X" and "U" (or "O" & "Z" as stated in one of the above posts) heads? Does one flow better than the other? Different springs? :BangHead:
      • 70aarcuda
        16,012
        4644
        Jan 16, 2005
        las vegas
        Local Time:
        7:11 AM
        Only to someone doing a resto on a AAR or TA.....otherwise they offer the same performance as a standard X or J head.....and If you were building a performance engine I would be looking at aluminum and not cast iron....JMO
      • Jadaharabi
        8,312
        9217
        Jan 8, 2016
        Peoria, Illinois
        Local Time:
        9:11 AM
        The letters were used at the foundary to tell the differant heads apart when they were cast.
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        18,837
        3241
        Aug 7, 2005
        92201
        Local Time:
        7:11 AM
        X heads end in casting number 894... nothing else for the 68-70 model years.
        All the other letters for performance oriented passenger car heads started in 1970 model year with the 915 head that you have.
      • gm1236
        157
        64
        Aug 3, 2013
        Massachusetts
        Local Time:
        10:11 AM
        In NHRA stock eliminator we have found the x head to be the best flowing unported head. Also the chamber has a slightly different shape than the 915. You can run the piston a little bit closer to the head than on the 915 castings.
        • Like Like x 1
        • RustyRatRod
          RustyRatRod Lemmie see your b00bs. FABO Gold Member
          67,661
          41881
          Jun 7, 2010
          Georgia
          Local Time:
          10:11 AM
          Unless they are TA heads nothing. The X heads all had 2.02 valves. "Some" J heads had 2.02 valves. I am not sure if any of the other letter heads did. But, unless they are TA heads, the only difference is either the 1.88 or 2.02 intake valve size. All the ports and chambers are pretty much the same. Even in stock form, the TA heads are the same except the 2.02 valves and the offset pushrods for porting the intake ports out. I believe even the ports in the TA heads are all the same as the rest in stock form.
        • Jadaharabi
          8,312
          9217
          Jan 8, 2016
          Peoria, Illinois
          Local Time:
          9:11 AM
          In the stock form there is the differant cfm between the differant heads. Once they are all ported to say 250 cfm at .500 lift with cc and valve sizes the same, J U or O or no letter on the head doesn't really matter.
