1. Rodsaknockin
    Rodsaknockin Well-Known Member
    140
    40
    Aug 31, 2017
    Canada
    Local Time:
    3:04 AM
    Hi are any of you guys running the xe285hl cam? Just wondering what it will sound and run like ?
  2. rumblefish360
    rumblefish360 So close, yet so far away
    36,094
    7960
    Jun 21, 2005
    New York, on a Island
    Local Time:
    5:04 AM
    Like a normal hot rod muscle car on a typical 110 C line.
    • Like Like x 1
    • toolmanmike
      toolmanmike FABO Staff Staff Member FABO Gold Member
      43,158
      26221
      Jan 18, 2006
      Iowa
      Local Time:
      4:04 AM
      What are you thinking about putting it in?
    • brian6pac
      brian6pac Well-Known Member
      4,249
      2692
      Nov 15, 2016
      N.E.Ohio
      Local Time:
      5:04 AM
      • Thanks! Thanks! x 1
      • toolmanmike
        43,158
        26221
        Jan 18, 2006
        Iowa
        Local Time:
        4:04 AM
        • Like Like x 1
        • brian6pac
          4,249
          2692
          Nov 15, 2016
          N.E.Ohio
          Local Time:
          5:04 AM
          HaHa it's still going to sound the same or very close and like I said it was the first thing that came up, I just wanted to see what would come up. It was better than saying it sounds like this thumpity thump. LOL
          • Like Like x 1
          • toolmanmike
            43,158
            26221
            Jan 18, 2006
            Iowa
            Local Time:
            4:04 AM
            You put that in a 273 and it will sound like a top fueler. Put it in a 408 and you wish you had one bigger. In a big block it sounds completely different.
            • Like Like x 1
            • 4spdragtop
              4spdragtop FABO Gold Member FABO Gold Member
              27,133
              6755
              Aug 28, 2009
              Ontario
              Local Time:
              4:04 AM
            • brian6pac
              4,249
              2692
              Nov 15, 2016
              N.E.Ohio
              Local Time:
              5:04 AM
              I ran a couple 273's back in the days when I was a kid, one had a DC 500 lift 292 dur solid lifter and some nice valve springs, that thing sounded awesome,
              That's when I learned about push rods. LOL
              • Like Like x 2
              • Rodsaknockin
                140
                40
                Aug 31, 2017
                Canada
                Local Time:
                3:04 AM
                Well plans are to put in a 360 with 107kbs and 63cc eddy heads dougs headers and a 750 double pumper
              • KnuckleDuster
                KnuckleDuster Well-Known Member
                1,734
                724
                Nov 9, 2005
                Texas
                Local Time:
                5:04 AM
                It sounds like this at 800rpm in a 410" with 1-5/8" headers, Flowmaster 40's and 2-1/2" exhaust.
                And this at about 4500rpm...
                (excuse the poor quality audio and wind noise on my phone.)
                • Like Like x 5
                • Rodsaknockin
                  140
                  40
                  Aug 31, 2017
                  Canada
                  Local Time:
                  3:04 AM
                  That sounds good I'm still debating weather or not to stroke it.
                • mderoy340
                  mderoy340 Well-Known Member
                  2,147
                  879
                  Aug 2, 2012
                  Melbourne FL
                  Local Time:
                  5:04 AM
                  pick a cam for best power not sound.
                  • Agree Agree x 4
                  • Rodsaknockin
                    140
                    40
                    Aug 31, 2017
                    Canada
                    Local Time:
                    3:04 AM
                    I agree Iam just a little concerned about my compression I think it is going to come out at 11.2 so just looking for a little more cylinder bleed off if I'm thinking right my 360 block is zero decked with kb107and 63cc heads really want to get it right the first time any input on this would be great. I have also been thinking about stroking it and getting different pistons and lower the compression some options for both ways would be appreciated
                  • mderoy340
                    2,147
                    879
                    Aug 2, 2012
                    Melbourne FL
                    Local Time:
                    5:04 AM
                    0 deck .039 gasket is 10.75
                    high 60 low 70 degree intake closing will run great on pump gas. 240ish @ .050 intake duration
                    • Like Like x 1
                    • Agree Agree x 1
                    • Rodsaknockin
                      140
                      40
                      Aug 31, 2017
                      Canada
                      Local Time:
                      3:04 AM
                      Thankyou for that
                    • nm9stheham
                      nm9stheham Well-Known Member
                      11,149
                      3218
                      Dec 20, 2013
                      Waynesboro, VA
                      Local Time:
                      5:04 AM
                      Yep, I agree; I get SCR = 10.65, with the same head gasket. DCR end sup around 8.2 for that cam at an ICL of 106. Should be runnable on pump premium; take care in tuning.
                      That is all at sea level.
                      What elevation are you at OP? If up at 3000' then DCR drops over half a point, so you might want to re-think if that is the case, depending on what you want to do with this. What is the planned use of this engine?
                      • Like Like x 1
                      • Rodsaknockin
                        140
                        40
                        Aug 31, 2017
                        Canada
                        Local Time:
                        3:04 AM
                        Street car for sure 3:91 rear end and Iam at 2500 feet elevation thanks for the info
                        • Like Like x 1
                        • Rodsaknockin
                          140
                          40
                          Aug 31, 2017
                          Canada
                          Local Time:
                          3:04 AM
                          I was going to go with the xe274 at first and one machine shop said the xe285 would be a better choice. I really want this thing to run good
                          • Agree Agree x 1
                          • nm9stheham
                            11,149
                            3218
                            Dec 20, 2013
                            Waynesboro, VA
                            Local Time:
                            5:04 AM
                            OK; I corrected my DCR numbers above so re-check. I had put in the wrong duration. That and 2500' elevation puts you at 7.7 effective DCR. So ought to be pretty torquey and take off pretty darned good with that 3.91. I don't think you have too much SCR by any means.
                            • Like Like x 1
                            • nm9stheham
                              11,149
                              3218
                              Dec 20, 2013
                              Waynesboro, VA
                              Local Time:
                              5:04 AM
                              'Run good' is somewhat hard to target..... Run good on the drag strip and run good around corners are 2 different things. I was thinking a 274 or 278 might be better IF you are doing a lot of powering out of corners on back roads. But, I keep forgetting that 3.91 gear....
                              • Like Like x 1
                              • Wyrmrider
                                Wyrmrider Well-Known Member
                                1,935
                                873
                                Sep 5, 2016
                                los angeles
                                Local Time:
                                2:04 AM
                                I would not use 750 double pumper on the street if I had to buy the gas
                                that 285 is a big cam for a 360 so it needs the compression you are going for but also gears and converter depending on how and where you are going to drive it you have 3.91 so you should be ok for hot rod use ?converter?
                                IDK about a drive to work daily driver.. it's going to be soft getting going even with the gears
                                If you need crank work and rod work and pistons then a stroker makes sense more torque more driveability
                                top end power is in the heads so no change there- and top end power is overated for a street build- you don't get there very often
                                what rockers? if roller tip price in a B3 kit and then 274 with 1.6 makes sense or go solid lifters like thousands of 273's- works fine
                                • Like Like x 1
                                • Rodsaknockin
                                  140
                                  40
                                  Aug 31, 2017
                                  Canada
                                  Local Time:
                                  3:04 AM
                                  I'm going to go roller rockers and solid lifters I was going to stick with 1:5 ratio and run a 2500 rpm converter I also have a 670 Holley vacuum secondary's and I have been reading about the efi systems. Maybe that's the way to go idk
                                • mopowers
                                  mopowers Well-Known Member
                                  4,223
                                  1341
                                  Feb 15, 2006
                                  West Sacramento, CA
                                  Local Time:
                                  2:04 AM
                                  Which 670 Holley do you have? If it's a street avenger, I'd keep it on the shelf. I tried one on my 340 and it ran like crap. For engines with a bit of camshaft, the idle circuits are way too lean on those carbs. You'll have to open up the idle feed restrictors to keep it from bogging down. The 750dp will be a better carb for the motor IMO.
                                  • Like Like x 1
                                  • Rodsaknockin
                                    140
                                    40
                                    Aug 31, 2017
                                    Canada
                                    Local Time:
                                    3:04 AM
                                    It is a street avenger I also have a edelbrock can't remember what cfm it is I think it is a 750. I don't really like them as well as a Holley
