FWIW, try that Edelbrock out, the engine will like the larger carb better.
Ok I will give it a shot. ThanksFWIW, try that Edelbrock out, the engine will like the larger carb better.
Being it is a 750, it is an AFB.Ok I will give it a shot. Thanks
And a 2500 rpm stall converter isn't near enough.Which 670 Holley do you have? If it's a street avenger, I'd keep it on the shelf. I tried one on my 340 and it ran like crap. For engines with a bit of camshaft, the idle circuits are way too lean on those carbs. You'll have to open up the idle feed restrictors to keep it from bogging down. The 750dp will be a better carb for the motor IMO.
Ok point taken if you were going to put a converter in what would your choice be ? The only reason I thought 2500 may work is because I have more compression than they require for the cam so I thought it might work. The other question I have is how do you choose a converter that is going to work well with this combination and still give you some drivability and Iam definitely not opposed to building a stroker I have my block ready and have the kb107s but i will and can go the other way I was going to send my crank in for a polish but I'm not in a panic I have the winter to get it all sorted out thanks for all the helpAnd a 2500 rpm stall converter isn't near enough.
I have not had the numbers ran but interested in it for sureWhat does a stock converter brake stall at? 1800-2000? 2500 stall isn't much. Anyone run numbers to see where the torque/hp curves look like.
Ok I had one old mopar guy that suggested this cam that with the compression ratio I have the 2500 should be sufficient now with that being said if I do go stroker then a 2500 stall should work really wellFrom using a smaller cam but a 10 SCR and 8 DCR on a 340 with a 2200 RPM stall, it is not the least bit soft from a standing start. I don't think 2500 is too small for your larger cubes since you have kept the SCR and DCR up. Easy to change the TC later if you do not like.
Ok so I guess the question is I either raise the comp or go to the 274 cam and 1.6 rockers. I really appreciate all the input I want this thing to be as close to the edge as possible. I'm trying to get the best recipe for this engine thanks againI run a 276/286/110 HughesFTH (230/237@.050) with a 10.9Scr/8.7Dcr, in a 367,on 87E10 @ 179psi @900ft....... and although it is a standard transmission,it will take a footstomp at under 20mph in second gear, and wind up at 7000 in a heartbeat. that 20mph is 1700rpm. In first gear, I can dump the clutch and stomp it immediately .This with 295s
At your elevation and subsequently lower pressure I would consider the next smaller cam, with 1.6s like Wyrm mentions and maybe on a 108.
At 2500ft IMO 11.3Scr is not enough for that 285 cam
IMO it is barely enough for a 272/108 FTH . You will be much happier.
I think I asked early in the thread, what is this going in?Ok so I guess the question is I either raise the comp or go to the 274 cam and 1.6 rockers. I really appreciate all the input I want this thing to be as close to the edge as possible. I'm trying to get the best recipe for this engine thanks again
Ok this info helps a bunch so Iam asking to much for 400hp and 450 tourqe with this set up or Iam going to be in the ball park. My former machine shop didn't want to go even 10.1 comp and more is better lol.A fast-rate 272 will be close to the edge for pump gas
Installed at 104 for an Ica of 60* and with an Scr of 11.3@2500 ft the Dcr comes to 9.3 and pressure is predicted to be 185psi@163VP.
If you go down to 800ft, the pressure climbs to 194 and depending on your tuning skills, there may be times when the engine gets into detonation on anything but the best gas.
If your intention is to stay at 2500, then you can run up to 200psi. To do tat you would have to decrease the ICA or increase the Scr. The former means a smaller cam and the latter means machine work.
To be continued
Thanks for the info Iam going to go parts shopping for a camA fast-rate 272/280/110 will be close to the edge for pump gas
Lets retard it to 106* for an Ica of 62*.. I get 182psi/158VP. Ok that should work.
If your intention is to stay at 2500, then you can run up to 200psi. To do that you would have to decrease the ICA or increase the Scr. The former means less Ica, and the latter means machine work.
The 285/110 has about 68* overlap, while the 272/110 has just 56, so the 272 won't idle as radically as the 285. If this is to be a city car, you can tighten up the 272/110 to as far as 272/104, and get back to 68* overlap for the sound. This will decrease the Ica to 56* and increase the cylinder pressure to a predicted 192psi@174VP a ridiculously high number. This would certainly be on the edge.
Maybe you could get a 276/282/108 In at 106, the Ica would be 64* and the pressure predicted to be 178/152VP there that is more sane.Overlap of 63* so it's getting closer to sounding like the 285 at idle.
>178/152 is about what I run and I have never wished for more
But how about lets go back up to the off-the-shelf 272/280/110 in at 106*this time for an Ica of 62* I get 182@158VP; oh yeah
Lets put it in your car with 4.30s
Your power peak will be near 5400 and a shift rpm of 6200, which will get you 45 in first, and a drop to 3660 into second and 65 will be 5300 badaboom there you go. The quickest way to 65
Or just a whole lotta tirespin.
the Cam should have been picked before or at same time compression chosen.
You seem to be picking compression and band-aid it with a cam.
Smaller than 750 carbs don’t really match 285hl size cam. If you are worried about mileage with a 750 dbl pump, pick a smaller cam and less HP build.
4” stroker with 285hl cam is pushing 500HP.
4” stroker with 9.5:1 compression and 274hl is around 425-450 hp.
I was going to run j heads but the machine shop cut into water when they were putting seats in long story.....that would of been at 10:1 with the kb107 and a 68cc combustion chamber according to the kb book any way I decided after doing the porting and having the head ruined I would go with aluminum heads picked edelbrock heads 63cc with 2.02/1.60 valves and performer rpm intake dougs headers the block is bored 40 over and zero decked. I had also picked a xe274hr cam but with the smaller combustion chamber I was steered into the bigger cam for some bleed off. I agree a bigger cam is not always better.What's the rest of your combination? Intake? Heads? Headers? A big cam doesn't always mean big power.
Aluminum heads with a small chamber are more efficient than cast heads and usually add a point of compression without detonation.I was going to run j heads but the machine shop cut into water when they were putting seats in long story.....that would of been at 10:1 with the kb107 and a 68cc combustion chamber according to the kb book any way I decided after doing the porting and having the head ruined I would go with aluminum heads picked edelbrock heads 63cc with 2.02/1.60 valves and performer rpm intake dougs headers the block is bored 40 over and zero decked. I had also picked a xe274hr cam but with the smaller combustion chamber I was steered into the bigger cam for some bleed off. I agree a bigger cam is not always better.
