You can’t trust thermostat ratings
Heating / Cooling / AC
  1. hotrod swinger
    hotrod swinger Well-Known Member
    254
    167
    Mar 6, 2020
    Sooke
    Local Time:
    1:06 AM
    I bought a 185 thermostat, it was stamped 185, yet my engine consistently runs at 170, no matter the season. Verified with a laser thermometer.
    Is it worth the time and energy to swap it out?
  2. toolmanmike
    toolmanmike Moderator Staff Member FABO Gold Member
    63,512
    53626
    Jan 18, 2006
    Iowa
    Local Time:
    3:06 AM
    I always test mine in a pan of water on the stove.
    • Agree Agree x 3
    • Like Like x 1
    • hotrod swinger
      254
      167
      Mar 6, 2020
      Sooke
      Local Time:
      1:06 AM
      Lesson learned.
    • Dana67Dart
      Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member
      8,286
      5804
      Jul 16, 2017
      Northern Colorado
      Local Time:
      2:06 AM
      Where are you measuring?
      Thermal temp guns don't work accuritely on reflective surfaces.
    • hotrod swinger
      254
      167
      Mar 6, 2020
      Sooke
      Local Time:
      1:06 AM
      I’m measuring a painted intake manifold directly below the thermostat housing.
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      81,515
      61127
      Jun 7, 2010
      Georgia
      Local Time:
      4:06 AM
      The thermostat hasn't a thing to do with how hot your engine runs. Nothing. The temperature stamped on the thermostat is simply when it begins to open.
      • Agree Agree x 2
      • 66fyssh
        66fyssh Don't Stop Believin' FABO Gold Member
        6,645
        6635
        Jun 22, 2013
        Northwest GA
        Local Time:
        4:06 AM
        I don't think I'd worry about 170*. But if it's going to be one of things that you think about every time you drive, make time to swap it out. I learned to bite the bullet on those nagging little things that take up my valuable gray matter, lol.
        I wonder if the laser thermometer could be off also? Could be a combination of the thermostat opening a little early and the thermometer reading low.
        • Like Like x 1
        • toolmanmike
          63,512
          53626
          Jan 18, 2006
          Iowa
          Local Time:
          3:06 AM
          The lazer's are quite accurate. They measure surface temperature and not coolant temp.
          • Like Like x 2
          • RustyRatRod
            81,515
            61127
            Jun 7, 2010
            Georgia
            Local Time:
            4:06 AM
            Correct. This is why any nurse will tell you to add "about" 3-5 degrees to an infra red gun if you use it to take a person's temperature. The temperature of your forehead's surface isn't quite representative of your overall body temp.
            • Like Like x 1
            • hotrod swinger
              254
              167
              Mar 6, 2020
              Sooke
              Local Time:
              1:06 AM
              I get that it has nothing to do with maximum temperature, but I had understood the thermostat dictates the minimum temperature, which is what I’m concerned about.
            • hotrod swinger
              254
              167
              Mar 6, 2020
              Sooke
              Local Time:
              1:06 AM
              Then again, if 170 is a good operating temperature I’m happy anyway.
              • Agree Agree x 1
              • MOPAROFFICIAL
                MOPAROFFICIAL FABO Gold Member FABO Gold Member
                10,116
                9458
                Jun 1, 2016
                Oceanside ca.
                Local Time:
                1:06 AM
                The thermostat rating is the temperature of which it is fully opened. The thermostat starts opening a lot sooner but it's not fully open until the rated temperature. Fact.
                You can take a 180 thermostat n put it in a pot of water on a lit stove..and with a thermometer in it you'll see it starts opening about 150 degrees.
                We learned that in HS auto shop class.
                • Agree Agree x 2
                • MOPAROFFICIAL
                  10,116
                  9458
                  Jun 1, 2016
                  Oceanside ca.
                  Local Time:
                  1:06 AM
                  You can use less fan, or a higher rating stat...but... idk. It's your car. Idt it would hurt it. There is an expansion rate at a given temp for cast iron and I guess you would want to maintain a range in regards to the clearances vs temp spikes @wot ...its really overthinking it though. Lol
                  • Like Like x 1
                  • dukeboy_318
                    dukeboy_318 FABO Gold Member FABO Gold Member
                    46,984
                    22952
                    Jan 19, 2007
                    No
                    Local Time:
                    4:06 AM
                    Ratings on anything anymore it seems have a wider tolerance band than it used too
                    • Agree Agree x 2
                    • AJ/FormS
                      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s FABO Gold Member
                      22,082
                      9244
                      Jan 19, 2014
                      South-Central Manitoba,Canada, 900ftelevation
                      Local Time:
                      3:06 AM
                      on a streeter, I would.
                      Yours is probably not closing all the way.
                      They say your street engine will last longer if run a lil warmer. I get great power out of mine at 205, and better fuel-economy on the hiway.
                    • MOPAROFFICIAL
                      10,116
                      9458
                      Jun 1, 2016
                      Oceanside ca.
                      Local Time:
                      1:06 AM
                      They've always worked this way.
                      It's hearsay on how they work that's confused people over the years.
                      • Agree Agree x 1
                      • hotrod swinger
                        254
                        167
                        Mar 6, 2020
                        Sooke
                        Local Time:
                        1:06 AM
                        Of course I ended up changing the thermostat. What else would I do on a rainy day?
                        I bought a 195, the one that was installed was a 180.
                        Tested both last night, both close properly, the 180 opens at 160 and the 195 opens at 185. I installed the 195.
                        • Like Like x 1
                        • harrisonm
                          harrisonm Well-Known Member
                          3,848
                          4319
                          Jan 16, 2005
                          Topeka, KS
                          Local Time:
                          9:06 AM
                          Gotta disagree with that. Everything I have ever seen or read stated that the temp on a thermostat was when it started opening. @RustyRatRod was an Oriellys manager for years, and I agree with him.
                        • hotrod swinger
                          254
                          167
                          Mar 6, 2020
                          Sooke
                          Local Time:
                          1:06 AM
                          These were the temps they started to open.
                          • Like Like x 1
                          • Thanks! Thanks! x 1
                          • MOPAROFFICIAL
                            10,116
                            9458
                            Jun 1, 2016
                            Oceanside ca.
                            Local Time:
                            1:06 AM
                            If that makes your butthole moist, sure.
                            No knock on Rob.
                            You're still wrong.
                          • MOPAROFFICIAL
                            10,116
                            9458
                            Jun 1, 2016
                            Oceanside ca.
                            Local Time:
                            1:06 AM
                            Thank you for actually doing the footwork most people either just believe or deny it and never tested themselves.
                            They start opening before the temp rating at which they are fully open at.
                            People think they just POP open..lol.. yeah.. a big pressure spike is what you want...not.
                          • MOPAROFFICIAL
                            10,116
                            9458
                            Jun 1, 2016
                            Oceanside ca.
                            Local Time:
                            1:06 AM
                            As they cycle the 195 will start opening a little sooner..like maybe 3-5 degrees sooner.
                          • hotrod swinger
                            254
                            167
                            Mar 6, 2020
                            Sooke
                            Local Time:
                            1:06 AM
                            Also my engine now runs at 180-200 instead of 160-180, so the thermostat definitely has an effect on operating temperature.
                            • Like Like x 1
                            • Agree Agree x 1
                            • MOPAROFFICIAL
                              10,116
                              9458
                              Jun 1, 2016
                              Oceanside ca.
                              Local Time:
                              1:06 AM
                              The post above yours proves you wrong too.
                              Lol did you miss that?
                            • Tooljunkie
                              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                              20,557
                              22979
                              Jul 22, 2017
                              Manitoba
                              Local Time:
                              3:06 AM
                              2 types of thermostats. Graduated and reverse poppet. Graduated are fully opened at 180, and poppet style start to open at 180. Quick open quick close. Poppet style typically cycle open and closed.
                              • Like Like x 1
