You've heard it before ?
Slant 6 Engines
  1. Matt Gentile
    Matt Gentile Active Member
    36
    25
    Jun 2, 2018
    MA
    Local Time:
    1:02 PM
    First slant six in my Mopar career...always 440's...now I want the challenge of the six that's in my newly acquired 68 Valiant . I have headers ( 2-3's ) , a Clifford intake ( with a single , dual and four barrel adaptors ) , will be doing an electronic distributor and full dual 2 1/4 exhaust...to start . So to start off , what carb ? Looking at a 390 cfm Holley 4 bbl or a 350ish cfm 2 barrel Holley ? Prefer not to dig into the engine , looking for reliability first , but if something looks do-able well....
    So anyways , I'm open to most anything as this route is all new , so what do you'ze guys think ?
    Thanks .
    • Like Like x 2
    • KosmicKuda
      KosmicKuda FABO Gold Member FABO Gold Member
      1,653
      479
      Jan 15, 2011
      N Ohio
      Local Time:
      4:02 PM
      I think you should post this in the /6 section.
      What are your goals for this engine and car?
    • Bad Sport
      Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
      37,002
      17355
      Jun 12, 2010
      The Wolverine
      Local Time:
      4:02 PM
      It is now. :D
    • Matt Gentile
      36
      25
      Jun 2, 2018
      MA
      Local Time:
      1:02 PM
      Sorry...
    • armyofchuckness
      armyofchuckness The Flying Valiant
      689
      107
      Aug 23, 2008
      Gainesville, FL
      Local Time:
      4:02 PM
      If you aren't doing anything to the internals, the two barrel Holley is the way to go.
      If you're going for an electronic ignition, you should definitely do the HEI conversion.
    • RAT ROD AL
      RAT ROD AL I know just enough to be dangerous FABO Gold Member
      2,845
      3089
      Jan 18, 2013
      St. James City. FL.
      Local Time:
      4:02 PM
      A few years back I built a /6 in a little rat rod , Put an Offy 4 barrel intake ,390 holley and performance cam in and it ran great.
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      10,721
      2534
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      4:02 PM
      You really need to up the compression to take advantage of any external mods. I decked my block 90 thou and cut the head 10. Should up the CR to around 9.5 to 1. I haven’t decided whether to go 4 barrel or triple Weber’s
    • justme
      justme Well-Known Member
      318
      73
      Mar 12, 2007
      long island new york
      Local Time:
      4:02 PM
      I use a 350 holley with pertronix and dual exhaust with Dutra manifolds, 833od. Lots of fun and i can cruz at 65, 75 very easily!!! Lots and lots of fun!!!
    • Matt Gentile
      36
      25
      Jun 2, 2018
      MA
      Local Time:
      1:02 PM
      On the 350 Holley...2 or 4 bbl ? And model...?
    • halfafish
      halfafish 66 Valiant, hot-rod in training FABO Gold Member
      964
      771
      Aug 14, 2016
      SW Washington
      Local Time:
      1:02 PM
      First off, nice score on the 68 Valiant. I'm jealous, while keeping an eye out for the same car. I agree with all the above advice. Making a master plan is important, what are your goals for the car? With a slant, balancing complementary parts is a huge part of improving performance as opposed to throwing parts at the project. Doing the HEI ignition and recurving your distributor are a good start. Living in MA, unless you only drive this on only your hot summer days you will regret not having any intake manifold heat. Does your Clifford manifold have the water jacket? A far better route for a street driven car than headers are Dutra Duals. Yes, they are now more expensive since they were bought out by Aussie Speed, but they really work and are worth the coin. If you don't want to get into the internals, you are wasting your time and money with any 4-barrel carb. You need a bigger cam, more compression, and head work to get any benefit from a 4-barrel. The 2-barrel Holley is a better way to go (or a Carter BBD, or a Ford 2100). For exhaust, on any slant full duals are not necessary. If you want them because you like them, then fine. But it's extra weight that won't improve your performance a bit. A single exhaust properly set up will be better and cheaper.
    • justme
      318
      73
      Mar 12, 2007
      Local Time:
      4:02 PM
      2bbl
    • RAT ROD AL
      2,845
      3089
      Jan 18, 2013
      St. James City. FL.
      Local Time:
      4:02 PM
      I still have the two 2barrel 2100 carbs that fit your intake. CHEAP !
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      17,330
      5778
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      3:02 PM
      3.40x4.125 stroke on the 225
    • Nige
      Nige Member
      13
      16
      Mar 9, 2015
      Victoria, BC
      Local Time:
      1:02 PM
      shave your head :eek:
      • Agree Agree x 1
      • /sixchall
        /sixchall Well-Known Member
        183
        106
        Jan 19, 2017
        Riverside ca.
        Local Time:
        1:02 PM
        For a little kick and efficiency I addressed my Six with (and this is a ‘77 model engine) a Mopar elect. Ign. With orange box and HO Accel coil. Then moved to an open element 14x3 K&N air filter, a Super Six intake and 2bbl Carter BBD, Hooker headers 3into1, real 2 1/4 aluminized dual exhaust w/ H pipe. 2 Glas Pak mufflers out to the back. A Nippondenso HO alum. starter for giggles. An 8 3/4 out back with a 3.23 gear set doesn’t hurt either, Auto. 904 all packaged up in a ‘70 Challenger. I think it sounds and runs great, nothing really over the top. Just damned efficient with 87 at the pump.
      • Slantsix64
        Slantsix64 Well-Known Member
        2,125
        776
        May 11, 2014
        SGV
        Local Time:
        3:02 PM
        Mill the head, and choose a camshaft based on your rear ratio and compression ratio. Adding more gas and air to a stock slant camshaft is death.
        • Agree Agree x 1
        • famous bob
          famous bob mopar misfit FABO Gold Member
          14,921
          5233
          Aug 14, 2011
          okla
          Local Time:
          3:02 PM
          6 cyl. w/ glass packs ? -----------------
        • AJ/FormS
          17,330
          5778
          Jan 19, 2014
          Local Time:
          3:02 PM
          3.40 x 4.125, makes a swept of 613.72;That's
          ~9% more than a 273(562.2), and
          ~94% as much as a 318(652.27).
          that's a lot, eh?
          Huyp, that will make, making cylinder pressure, a little easier. And you only have to cut ONE head, and it doesn't mess up the valley seal,lol.
        • /sixchall
          183
          106
          Jan 19, 2017
          Riverside ca.
          Local Time:
          1:02 PM
          not as bad as it sounds Bob! 2, 26” on each pipe with the H pipe connecting the two separate pipes together, at idle at the back it has a nice almost small block rumble.when I take off then you get the 6 cyl. sound. Thanks, Al
        • famous bob
          14,921
          5233
          Aug 14, 2011
          okla
          Local Time:
          3:02 PM
          I just changed solid roller cams, mine makes more noise underneath now than it did w/ a hair bigger cam ???
