Z-Bar ?
dusterdemon
southern Indiana
How can I tell the difference between a /6 and a V8 Z-Bar? I think there is a difference in length, but I don't know what the correct length is for a V8 car. Thanks Warren
The only difference between the \6 and sb v8 bar is the length of the tube. All of the additional length is on the block side. I modified my \6 z-bar by cutting a little more than an 1" off the block side.
If you need actually lengths Brewers should be able to help you with that info and can sell you the one you need.
Thanks for the reply. Could someone give me the length of the tube on a small block V8 Z-Bar, so I can determine if mine is for a V8. Thanks Warren
Warren, I just measured my Z bar and it is 7 inchs wide on the button. It is from a 65 Cuda. I don't know if these are narrower than the 67 up A bodies.
