[Found!] 70-71 dart fender extension driver side
Fast340cuda
San Jose, ca
Looking for a good driver side fender extension for a 70 or 71 dart or demon. Prefer the cast version but will consider the fiberglass type. My car currently has a nice 72 style that I would like to swap out with the correct piece. Let me know if you have a spare laying around. Thanks!
Here are the issues
70 - to early 71 deep are fiberglass which cost the most because you can replace the studs and fit all three years
71 - early 72 deep are a pot metal the studs are also pot metal and break very easy . They can be change to 10/32 stepped up studs but good luck
72 shallow are pot metal and have screw in studs. Just some info you may want to use. Shallow and deep are determined by the eyebrow chrome you have.
If you ever felt the weight difference between glass and metal you would be surprised . I like using the 70 fiberglass style.
