Power Lok Clutch sequence
340sFastback
Maryland
I have an original 8 3/4 Power Lok that I just bought and it came with an NOS clutch kit and NOS thrust spacer kit. The seller told me the 8 3/4 power lok clutches go in a different order then the Dana power lok clutches. Anyone know what order the dished plates and discs go? This diagram shows the order for the Dana (scroll all the way down):
http://www.moparts.org/Tech/Archive/axle/13.html
If you have 5 discs and they are the same set up, they go in the same way.
That's the way I put all power locks together.
If the discs have friction material on them, soak them in straight friction modifier overnight before assembly.
Maybe ask Cass, Dr. Diff, over at Moparts to verify. I may have been putting them together wrong for years, but, they never had an issue.
Dana 60 and 8 3/4 are different. Clutches load this way in 8 3/4.
340sFastback: If you would like the instruction sheet for installing the clutches, I can e-mail them to you.
Just a note: Part#P4529484 clutch pack for 8 3/4.
Part#P4529485 clutch pack for Dana 60 or 9 3/4.
Thanks for the info. PM sent.
Demon416, you have PM
Pulling up this old post for info. Do the dished plate and disc both face the same way so their middles touch or opposite so their outside edges touch. I,m guessing the same way but dont like guessing.
This pic might be a little clearer and show the detail better,especially on a phone haha.
Like stated above, same way.
