Pinion angle 904 vs 727
tjpatte
San Diego
Trying to determine if the engine/transmission centerline angle of a small block would be the same with a 904 and 727.
Going to be a while until I get the new engine/transmission in and wondering if I can setup the pinion angle for the rear axle using the current small block and 904?
Thanks!
Why would they be different? !!!YES!!! That is a SERIOUS question!!!!
Didn't know if the transmission cross member mount flanges were the same height between the two transmissions.
Edit: mounting flanges are the same from bell housing to mount and from mount base to centerline of the shaft.
