[FOR SALE] 1969 Barracuda 383 4spd formula S
jaws
I put the fun in dysfunctional
Strasburg Colorado
Don't know if I have another one in me. So, putting this out there. Barracuda formula S 383 4spd car, has a 727 in it at the moment. The motor is a 68, but is an A body motor with the manifolds. Core support, fender tag, dash, and trunk ledge match. I have new sheet metal for the car, both quarters, outer wheel house, trunk extensions, dutchman panel, rear valance. Car is B5 blue, white top and int. Some where in the past a valiant dash was put over the cuda dash. There is a small rust hole on the left rear frame rail but should be an easy fix. Floors and trunk are good, front and rear seat have been redone. 13,000 or best.
whats with incorrect dash fame and cluster? That is a no bueno!!!
He cut the back out of the valiant dash and put it over the rally dash frame. I pointed it out in a picture. Don’t know why he would do such a thing. Vin is still on original dash frame in the car.
yes, I haven't pulled the Valiant dash to see if it's been cut or not though.
VIN plate is there that's good. rally cluster gone I'm thinking. dash Would be possible to fix I believe a bit of sheet metal welding and prep etc.
I have a rally cluster that goes with the car. Also a rebuilt 4spd.
