5.7L Hemi Parts-Mich
6PKRTSE
Motor City
Rating - 0%
0   0   0
-5.7L Hemi fuel injection set ups containing the following components:
(5)with throttle bodies, injectors, injector rails, spark plug wire assy's etc $250.00 ea. , Air cleaner box assy (6) $40.00 ea. , Flywheels (7) with hdwe $40.00 ea. , Complete engine bay wire harnesses (2) $100.00 ea. , idle pulley (5) 15.00 ea., tensioner pulley (5) $15.00 , Exhaust manifolds heat shields (6) $5.00 ea. Emissions tubes $5.00 ea. (2) many bags, boxes of NOS mounting hdwe, clips & fasteners etc.
Most brand new NOS in packages or slightly used (Dyno time only). Some part #’s may be Engineering #’s or production #’s.
6-53032453AB-air filter mounting trays
6-53032405AC-air filter lids
6-53022169AC-air filter breather tubes
6-53032463-air filter element box
1-56051069ADA-engine bay wire harness
1-56051069AF-engine bay wire harness-SOLD
6-53032208AG-exhaust manifold heat shields
5-52088656AA-Plug wire looms
5-53032770BA-Air cleaner to intake air boxes
5-53032120AC-Throttle bodies
5-53032777AB-Upper intakes
5-56028502-temp sensor plugs & harnesses
5-53032772AB-Under intake Foam heat shields
5-56051399AA-Injector harnesses
5-53032531AE-Oil filter cap assy’s
5-53022712AB-Fuel rails
5-sets of spark plug wires
7-4736604AA-flexplates with hdwe
2-4711898 bellhousings
5-53032404AA- air filter elements
Bags of 52277576 clamps
Bags of 04268295 rubber boots
Bags of 53032537AA air inlet tube clamps
5-53032645AA idler/tensioner pulleys
Bags of 06506688AA bolts
Bags of 53032540AA air intake clamps
Bags of 06101695 Hex Nuts
Bags of 0527442AA air cleaner hold down clips
Bags of 06507442AA hex bolts
Bags of 06502282 flanged head hex bolts
Bags of 06034247 4” long hex head bolts
5-53032406 air filter lower box to throttle body (says 5.7L Hemi Magnum on it)
