Ironmike
Awesome! That's some skill there, brother.
That is some really nice improvements!!!!!Took 6 weeks to get Manley 2.08 and 1.60 valves, keepers, LS springs (ya I didn’t stutter), spring locators, and valve locks. Well 5/16 locks came instead of 11/32. Took somewhere around 3 months to get this right minus -040 or -.050 pac 11/32 keepers needed with this spring to get the required spring pressures. The spring is only 1.280 diameter. I never do 2.08 heads for customers but this is a very good friend. Honestly I wouldn’t have done them to this size if I knew what chamber size I was limited to but with extra work they turned out ok. I was a nervous wreck assembling these small azz retainers and keepers not having a single spare but they are ready for pickup. These heads were ported by a friend before so I had a few repairs to do and had to cut them for the required .500 valve seals. Before and after numbers. Should work pretty good with his .680 lift roller cam.
Have you ever tried your hand at a set of Hughes engines big mouth heads with the 2.08 valves , wondering if they left anymore flow with hand finishing , thanks
