Moparturbo
Thank you
No 7 1/4 here LOLThat could be considered a good thing if he’s crazy enough to run a 7.25“ diff, right?![]()
Start making boost? Depends on load. But I’d bet it won’t reach 10 psi till around 4000.what RPM would you say it will start making boost?
Has J heads. 650 double pumper on E85.What heads? Induction? And the 3:91 gear will hurt not help. A 3:23 gear will load the turbo more. Keep the converter tight and low/medium stall speed.
True I see you point, a smaller turbo would be better more useful.I have to respectfully disagree. That’s exactly the size gt45 I was talking about when I said it would be lazy on a mild 318. It’s a 1.05 AR hot side also. @Moparturbo, that will work and it will make boost, eventually, but something in the lower 60 mm range would be much more enjoyable to drive on a mild 318.
I like the e85 and the 650dp. Have the J heads been cut? If not with your 318 bottom end and xe268 cam, i see your compression ratio down in the 7s.Has J heads. 650 double pumper on E85.
I have a 340 short block with the 3.58 stroke and low compression forged pistons. I was just wanting to use the 318 as a test mule for tuning before I use the 372.There's an easy fix to all this. Find a cheap 360 and do all the same shnitt to it with the same parts. Get it up to 9:1 compression, with a mild cam. 325-350 hp build. Now add gt45.
Ahhh. Well then, stop worrying about it and get the gt45.I have a 340 short block with the 3.58 stroke and low compression forged pistons. I was just wanting to use the 318 as a test mule for tuning before I use the 372.
Blow through carb and E85 is all new to me.
I appreciate the help. I do not have the turbo yet. I was just thinking I could use that cheap GT45 to start with and even use it later on the 372 if it worked ok. I just got the MLS head gaskets and head studs so I plan on putting the engine together at the end of this month.Well, I don’t want to spend your money. If you have the gt45 already just stick it on and get to tuning. If you were gonna keep the 318 and make it the primary engine then there are better choices for a turbo. Either way post up what you do.
Nice. Like @Mean416 said, make sure you gap the rings.I appreciate the help. I do not have the turbo yet. I was just thinking I could use that cheap GT45 to start with and even use it later on the 372 if it worked ok. I just got the MLS head gaskets and head studs so I plan on putting the engine together at the end of this month.
It is. On wastegates it makes ~800 on pump gas and in a 21 foot boat it’s more than enough to put a terrifying look on passengers faces.Wow That looks like fun
Not yet. I actually tore the 318 down more than I expected. I am going to throw some new rod and main bearings in it. Hope to get it back together in about a month.@Moparturbo have you talked to any turbo suppliers yet?
