I do too but I think it's because I'm use to them being on thereThey look like they should be on a truck.
Funny, my son ran his Belvedere around for almost a year, cop caps on one side, plain dog dish on the other side to figure which he liked more, NOBODY noticed, or at least said anything.Just match them on the side. No one will notice. Lol.
Probably an unpopular opinion, but I like the ones you have on the front better.
I'm excited for you. Lots of work to get to this point. I'm anxious to drive mine and my swap isn't starting for another month. Still can't believe I'm swapping a perfectly great running car... Oh well, that's what hot rodding is all about.Picked up the final piece of the puzzle yesterday. Having some coffee and heading out to the shop to start putting everything together. A little bit to do actually.. Make brake lines, install the rear, assemble ebrakes hubs, axles etc. I feel pretty driven this morning so it should go well.
After swapping Hoopty, I'm hooked! I tried to love the Dart as it was, but after getting a real good taste of a Hemi swap.. I just couldn't. I had so much buyers remorse and I just knew there was only one cure... I got a fever and the only prescription is...I'm excited for you. Lots of work to get to this point. I'm anxious to drive mine and my swap isn't starting for another month. Still can't believe I'm swapping a perfectly great running car... Oh well, that's what hot rodding is all about.
I applaud your effort. This is a perfect example of why sometimes, we must fail.I tried to love the Dart as it was
5.7 / 8HP70Hoopty has a 6.4 hemi too?
I bet that is a blast to drive!5.7 / 8HP70
Did some driving yesterday.. All went well but I am going to make a few changes before really turning it loose.
Brought it around and rinsed things off
Burnouts.. Yes!
Yes, the vvt and non vvt is clocked different. Everything looked good when it went together and came apart with new o ring. I'll replace the oring this time as well. I've read threads on other forums of similar oil pressures. Actually seems pretty common... I just don't want to be thinking about it all the time.No Bolts Left Behind on YT had an issue with the oil pressure on his 5.7 swap and it turned out to be the wrong pickup. I guess the tab is clocked differently between a VVT motor and no-VVT motor and he had the wrong one so it didn't bolt down square and allowed for a leak. Based on your picture, doesn't look like that is your issue, but maybe the o-ring got kinked or cut during installation?
Right on brutha.. She (Dottie) gets cooler by the day. Finally growing out of the crazy pup stage.LOVE IT!!! Cool dog too!![]()
FANTASTIC!!! Give the dog a hug for me!!Getting close.. Motor is back together and Arp wheel studs done on 1 side (only 1/2 my order came in) and the wheels fit great with 1/2" spacer...i just need to decide on optimum tire size for the 6.5 wheel.. Plenty of room. The other 5 arp studs should be here today.
Not much left on my list now.. For a while, it felt like it was growing exponentially. Still need to do studs on the drivers side, put AC vents back under dash, charge AC, tirrs, alignment and rear tires... Ummm, I think that's it till next winter. I wouldn't mind doing a front disc swap this summer but for now, I'm eager to drive.
BTW, if you've never done 8. 8 parking brakes with axles in.. Omfg! It's hard enough when the axles are out! If you're doing an 8-8..just put them in while the axles are out.. As a precaution. Your wheels may surprise you.
She's waiting to give you a kiss!FANTASTIC!!! Give the dog a hug for me!!![]()
AWE!!!She's waiting to give you a kiss!
