stroker402
1968 dart GTS convertible
Thanks Mike !Sounds great.
update :
here's a little video of the 273 commando running thru the gears . "not a beat run sorry" . everything is running perfectly the way it should . I did down size to a stock 500 cfm afb carb after this video . and it ran much better with the 500 cfm than the holley dp 650. This new engine sounds much different than the last engine that came up with bad bearings .
In this new rebuild commando 273 , it has the 10.5 pistons vs the previous engine that had the 8.8:1 flat tops and a big erson cam 510-286 with no compression . now a ld4b vs the previous ld340 , clean up ports and gasket matched the 920 closed chamber heads .......
.... when you shift between gears with the new 10.5 engine it sounds like a harley motor cycle now .da da da da da when you shift between gears , like it has a lot of cavenging effect thru the headers . maybe you can hear it in the video. long tube 1 5/8 hookers into 2.25 head pipes the to 2.25 flow 40s' in and out , dumped before rear end. new cam is a isky t-3 455 lift 260 dur. 104 lsa with 2 degrees built into custom grind cam , 2000 - 6400 .
I think it sounds more like a harley now because of the higher compression or could use some quieter mufflers / x-h pipe, what do you think ?
nobody believes me when I tell them it's a 273 commando . It has a nasty Growl , and it's really loud with the flowmaster 40 series mufflers. video doesn't do it justice .Sounds like it has a pretty healthy idle. (for a 273)
Single or dual exhaust? Any videos of it idling?nobody believes me when I tell them it's a 273 commando . It has a nasty Growl , and it's really loud with the flowmaster 70 series mufflers. video doesn't do it justice .
duals Mike. I'll see if I can find a video idling .Single or dual exhaust? Any videos of it idling?
mike .duals Mike. I'll see if I can find a video idling .
Uploads are so slowmike .
I have only one good video of my commando idling but ...... I have the same trouble as before down loading a video anywhere on the net. why is it so hard!
my last 273 came up with bad rod bearings , but I didn't build that engine and it had sat for 27 years in texas. it was a fresh rebuild then from what I could tell. it evidently had some oil issues. but all in all , it's how you build the engine and how high you build it to rev I guess. don't use too big a cam that you have to rev it to the moon . take it to stock specs if you want it to last .5200 stock commando .Sounded good...real good. Sorry I didn't keep up so much after your head gasket delima but I did run across a 80's or 90's Fel-Pro gasket catalog that was offering some thicker type gaskets for all makes of motors. I put it away but will get the info to y'all. I had another question about the builds the various Hot Rod magazines weer doing with the 273 from about 1966 thru 1967 with most cautioning about going over the 4500 RPM with these little motors. Any input from you guys on that ?
I was going to try use you tube upload and I could see where to click on to start . I had used you tube before but it won't work now.Uploads are so slow
Video success ! here it is . enjoy !
Yes , this is the Isky custom grind t-3 solid cam. here are the specs .That's a sweet 273. Is that the T3 Isky, is sounds great. I have to get serious about my 273. Looks like you do have a little beast there. Great job![]()
Yep a little bigger than the E4. .425 lift 216° @ .050/260° 108°Yes , this is the Isky custom grind t-3 solid cam. here are the specs .
455 lift 260 duration advertised [email protected] , 108 lsa with 2* built in , 2000-6400 , lash .018 hot - .020 cold , my vacumn is 15-16 @ idle . Idles @ 800 rpms. it's just a tad bit larger than the e-3. call Ron @ Isky for more info if interested.
I have approx 60 miles on the commando now and it has more torque and hp than last engine . Haven't taken it over 4500 rpms yet , but it really feels strong . Revs real fast , has a totally different sound than last engine also. Compression "Does" make a difference !
Thanks for the cam info Stroker,Yes , this is the Isky custom grind t-3 solid cam. here are the specs .
Very much so Mike ! lolSounds quite spirited! LOL
Oh Yes........ these little commandos love to rev. Have my distributor with the pertronix rev limiter set at 5500 for just cruising around town . I had it set at 5900 at one point , and it felt really strong .Sounds stupid to me. My brother and I both had 273's most of our lives growing up. My 4 speed Barracuda was never shifted less than 3,000 rpm and was usually wound up to 6,000 for fun. Redline was 5,200 for the Commando and that really small cam. My brother had a 67 auto Barracuda, 273 2 barrel, converted to 4 barrel with just the intake, carb and quick curve distributor. He had a vacuum gage but he never allowed the trans to shift on it's own. He shifted by sound and feel. I'm sure that engine saw rpm well above 4,500 on more than a few occasions. It is still running with 300K on the odometer.
