Are you ready for an in-car camera pass ??!!!!
Update. The Duster ran an all time best 9.75 @139.8 at the valley this past Saturday. Pics and vid of the run will be up shortly.
Here is the slip
Motor is a 393 cubic inch small block with aluminum heads by Joey Arrington (builder of NASCAR Truck Motors). Custom intake manifold, roller cam and rockers. Titanium retainers and Ross Pistons. Holley 1050 Dominator carb. Moroso electric water pump and fan. MSD 7al 2 ignition with 2 step. Custom made sheet metal Moroso valve covers. Manual transmission is a Liberty 5 speed with a Lakewood steel bell housing. 11 inch adjustable long style clutch(gotta step it every shift) with 7lb aluminum flywheel. Shifter is a Long with V-gate and line lock. Mark Williams drive shaft. Rear is a shortened Dana 60 with 35 spline Strange axles with spool and 4.56 gears. Rear suspension is a 3-link with 12 way adjustable coilovers. 4 wheel Wilwood disc brakes. Front suspension is 8 way adjustable shocks with the AlterKtion conversion.
