Post your wheel and tire combos.
oops sorry got carried away looking at that cool duster anyway mine are 15x7 dodge diplomat 235-60-15 bfg drag radials and stock 14x5 195-70-14 fronts el-cheapo got the drag radials off craigslist for 125.00 went home and sold the chevy wheels for 100.00 25.00 for the rears pretty frugal huh?View attachment 178163
Car year and model---1973 Duster
Front
Wheel Brand--Weld wheel Draglites
Size--15"x3.5"
Backspacing--1.75"
tire size--165x80x15
Suspension mods-Stock with drag shocks
Rear
Wheel Brand--Weld Draglites
Size-15x10
Backspacing--7"-7.5"
tire size--28x12.50x15 M/T E/T Streets
Suspension mod--Super Stock springs with drag shocks,spring relocation kit.
here is pic of my 1973 duster with BF Goodrich radial T/A 275/60/15 on the rear and 225/60/R15 on the front.
On stock rear end with stock 15 inch rims
here is pic
69´ plymouth valiant 318
throque thrust replica (brand unknown)
front tyre:215/55/17
back:235/55/17
with adapters
So if you run a 15 x 8.5" wheel with a 5" back spacing (largest for A body Mopar (1970 Dart w/stock wheel wells and no mods), what is the largest tire that could be run hieght and width? For a rear tire and wheel combo and would run 14" on the front.
bon-speed wheels
rear 17x11 285-40-17 4 1/2 back
front 17x7 215-45-17 4 3/4 back
Wheels Front: WELD 15x5- 3 1/2" Back Space
Tires: 195-65-15
Rear: WELD 15x9-5 1/2" Back Space
Tires: 295-50-15
NO SUSPENSIONS MODS
So, I just went through 11 pages here. Couldn't find out what I wanted to know for sure. What's the largest 15" anybody has managed to safely stuff into the stock sized rear wheelwells of an early (64-66) Barracuda with the offset springs? Has anybody ever managed to fit a 275/60 15? Or is a 255/60 15 the biggest that will fit? Does anybody make a 265/60 15?
Anybody close to me that has a worn out 275/60 15 Radial T/A they want to throw my way for mock up? Or maybe a 255/60 15?
It's still on jack stands but will be on the ground soon!!
325/50R15 Drag radials on 15x10 with 3.5 inch bs Mini tubbed and springs relocated, narrowed Strange 60
195/65R15 Michelin's on 15x6 with 3.5 bs BBP disc brakes conversion
68 dart 440
Front
Wheel Brand - centerline lazer II's
Size - 18x8
tire size 235/40/18
no mods done that would of changed stock fit
Rear
Wheel Brand - Centerline lazer II's
Size 18x9.5
tire size 255/40/18
4.5" backspacing
im very happy with the wheels but will never order from centerline again.
wheels just fit
Wow, Joe, your car looks awesome! What a presence!
So what's the scoop with CL wheels?
Clair
I grew up in KC during the 60s and 70s. Went to Winnetonka.
I'm sure a bunch of us have seen this Dart floating around the interwebs. I've been searching through out the four corners of the internets and can't find the specs.
I want the same exact tire/wheel combo for the front and back as in this dart. Apart from the wheel wheel cutouts, does anyone know if the owner mini-tubed it? I love the stance on it, to my opinion it is perfect and want such look on mine! =P
I want the same exact tire/wheel combo for the front and back as in this dart. Apart from the wheel well cutouts, does anyone know if the owner mini-tubed it? I love the stance on it, to my opinion it is perfect and want such look on mine! =P
Hemi Dart specs:
Front 14"x5.5" big bolt D-70/14
Rear 15"x8" (special offset) 7.75"x15"
A hanfull escaped with a 8.15"x15" blue dot in the rear.
Not sure if this is the same as the pic,but these are the numbers I came up with.
Clair
It took over 8 months of getting lied to to get my wheels. The fronts were wrong when i got them and had to order two more because they refused to take them back. It took another 4 months to get my front wheels in. The powder coat was barely covering the aluminum and will turn brown in the corners when the sun hits it, also is flaking off in spots. Terrible customer service.
Finally got my bbp conversion finished up and got my new rims & tires on.
These are Rev-wheels (liscensed by american racing), Classic 100's
Fronts are 15"x6" with 205/60/15 BFGoodrich T/A's
Rears are 15"x7" with 225/60/15 BFGoodrich T/A's
Finally got the Polyglas on...E70x14 on fronts, G60x15's with 8" rallys on the rear AND Yes they ride like hardened donky Sh*&^...all over the road (Mighigan roads, the worst in N.A.) but they sure look great. Met with the Hot Rod Power Tour yesterday north of Detroit; lots of comments.
That pic was very edumicational to me. 1st the gray Wheel Vintiques centers don't look that bad but not as good as the 5 point centers stock. Second it looks like you have to use the right chrome wheel cover to get the right rally reflections.
I need a pair of narrow 14 trim rings for the front and a set of proper 15" deep rings for the rear.
Stock 318 Auto 8-3/4
BF-Goodrich Radial TA's
Front 15x6 Cragar/SS 215-60-15
Rear 15x7 Cragar/SS 225-60-15
