fstfish66
felpro with built in O RING blown motor 15 years
just take the rivets out and it should address the issue.
they have a viton seal, so pitting would be from the leaks you were dealing with
not defending cause i really dont care, but most manufacturers utilize the MLS design anymore.
It just seems that you missed it in your mock up stage and it cost you.
I can't mock up a engineered problem, the gasket fit good and looked good. Can't do much more than that.
I use Cometic in both my street 340 and my race 416. No problems but I always Copper Coat them at least 2 coats.
What part number you use??I use Cometic in both my street 340 and my race 416. No problems but I always Copper Coat them at least 2 coats.
NO offense man - but you never ever expect an engine to fall together without issues. Engineered problem? when you have several manufacturers going into a build like this you have to expect to check every thing several times.
It did not fit good, hell it didnt even look good - that bottom one you could see during the mockup stage
you need to look around the head to see the rivet under the deck, but it's just part of the process. Things get missed, I understand that but you really cant blame that on an engineering problem.
